Todd Ciccone Posted on May 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have identified the circuit casuing a humming in my house how do i proceed to fix it?
Mark Williams
Level 1:
Habit-Forming:
New Friend:
  • Contributor 8 Answers
  • Posted on Jun 03, 2016
Mark Williams
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
8
Questions
6
Helped
2578
Points
22
Check the breaker for that circuit, and especially the wires and connections.
KeCa
Level 2:
Sergeant:
  • Expert 181 Answers
KeCa
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
56600
Points
985
Here are some of the reasons: Electrical Hum Causes Solutions
Please contact an electrician for wiring changes/repairs.
I just bought my house. I have all electric baseboard heat. One of them has started to make this high pitch humming noise. I cant find anything to identify what type of heater it is, nor do I know how
Could be just an AC hum do to time and previous heating expansion/contraction altered it's characteristics.
You could [this is a crude way} just kick it to see if that stops the humming other then that completely dismantle it and reassemble it tightening the connections and support structure
I don't know what your heating/electric bill is $$$$ but my experience it's cheaper to heat with some other form of energy and in case of power outages you can heat your house using a generator where as electric heat you can not
Humming sound from subwoofer
hi Eileen Beamish,
One reason you found it in ......... , is that , These unit have a problem.
Humming is the main problem.
Resolved first the humming , then it will answer your questions
when you have succeeded repairing your subwoofer system.
It is irrelivant for now.
Here is a guide , how to repair or diagnose circuits which can cause
like the symptoms your having.
Computer Speakers
you can post an image or a picture just to help you identify which
possible board or components to check, only if you need to Diy.
JVM1750sm1ss micro-oven, totally dead when plugged in.
see the diagram and proceed with common sense use the VOM
God bless you
7_17_2012_2_10_43_pm.jpg7_17_2012_2_11_13_pm.gif7_17_2012_2_11_40_pm.jpg7_17_2012_2_12_03_pm.jpg
GE electrical house breakers keep tripping. Any problems or recalls
You may have overload that power circuit with too many appliances.
Check the load of each of the appliances on that power circuit, add them together and check to see that it does not exceed the rating of the circuit breaker.
OR
You have an overload or short/fault on an appliance on the power circuit that is protected by that circuit breaker.
To identify the faulty appliance, disconnect all the appliances on that circuit and then connect each appliance one at a time to see when the circuit breaker trips out. When that happens you have identified the faulty appliance.
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
What causes protection circuit? How to fix.
Usual cause is a blown power amplifer.
The usual cause of this is shorted speaker leads or excessive load casued by high volumje levels.
1helpful
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 • Garden
 Grubhead
Grubhead
SmartAviator
SmartAviator
