SOURCE: Recovery CD
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
Brett.
SOURCE: touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
SOURCE: I have a Panasonic Toughbook
For that you need to download driver and reinstall for touchpad then it will work again.
For getting touchscreen driver click here then select your model and os then download and install driver.
Also check below.
Click on Start > All Programs > Fujitsu Touch Panel (USB) > Touchscreen Calibration Utility.
Using the stylus, touch each of the 12 '+' target marks one by one until it blinks.
Click [Calibration].
Click [Save & Exit].
Then you can use it.
Let me know if you need further assistance.
Thanks for using FixYa.
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
Testimonial: "The tablet does not have a sim card. Just a basic tablet with a number password instead of a pattern. many thanks"
