Question about Fuji FinePix S2 Pro Digital Camera
Location of serial number for Fuji Finepix S2 pro camera
Posted by joseph pericci on
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
Anonymous
  • 6 Answers
SOURCE: Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Posted on Jun 14, 2008
Anonymous
  • 8 Answers
SOURCE: Fuji FinePix S2 - image records in black
Could be CCD Failure ... known as ' Black Screen of Death'.
Have CCD cleaned at a reputable camera (not chain) shop and they'll test it.
Fuji were replacing units suffering this problem at one stage.
Posted on Sep 22, 2008
Ty Price
  • 11967 Answers
SOURCE: I have a Fuji FinePix Digital Camera S602Z. I
Go to the support section of the Fujifilm web site.
Posted on Feb 27, 2010
Anonymous
SOURCE: Fuji FinePix S2 Pro won't turn on
Do you remember what did they do to reset the camera ? Can you share, please ?
Posted on Dec 08, 2010
this was found at fuji
  • Q.Where can I find the serial number of the digital camera?
  • A.The serial number is printed on the label attached to the bottom of the digital camera.
Where can find the serial number of the digital camera
May 06, 2016 | Fuji FinePix S2 Pro Digital Camera
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
I have puchased 256 mb card, used. Will I be able
Yes, you should be able to use the 256mb CF card. The Fuji S2 Pro will accept CF cards up to 2gb.
Jan 09, 2010 | Fuji FinePix S2 Pro Digital Camera
I bought a 4 gig CF card for my fuji S2, and when I intiailize the card, I get a "card error". Is my card bad, or will my camera not support such a high gig card? 1 gig cards work fine.
From administrative tools in the control panel on a pc,you can format a 4 gig card to fat (not fat32) in the disk management window. It works fine in my Fuji s2.
Oct 13, 2009 | Fuji FinePix S2 Pro Digital Camera
My fuji FinePix S2 Pro is processing images with a blush tone through out my images. What's wrong with it?
Could be a white balance setting or you've accidentally engaged a digital filter. You could try a camera reset. Go into the setup menu and scroll to "reset". This will take you back to the default settings.
Sep 22, 2009 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
May 05, 2008 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
