Did you ever figure this out? I'm having the exact same problem and came across your post.
thanks
[email protected]
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
SOURCE: need manual with the schematics for the wiring of
Need to know what year the club car is. No drawings are in the owner's manual and there are no free service manuals available.
But all is not lost, try buggiesunlimited website for downloadable wiring diagrams. If you still have problems I can maybe help lead you through some trouble shooting steps. email is [email protected]
SOURCE: Need a schematic for a club car golf cart
new batteries-36 volts--can,t get power to motor------ help please
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
