Question about Tablets & eReaders
Zeepad does not open/reset to manufature setting
Since I bought the zeepad around christmas for my 10 year old daughter I had 3 different people working on this pad over the lst 4 month ---NOTHING---- it is not working ====please help me== thank you very much Brigitte
Posted by brigitte scherer on
steve
  • Tablets & eR... Master
  • 1,692 Answers
Hi Briditte, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Posted on May 05, 2016
1helpful
How do you reset the zeepad when it wont turn on?
It is different depending on which zeepad you have. From powered off, which yours sounds like it is:
1. Hold down both volumes and power at the same time. You should get an android on its back opened up.
2. Press both volumes at same time to open up a small blue text menu.
3. Then use Vol - and Vol + to navigate the Recovery mode.
4. Select "Factory Data Reset"
5. press power
6. choose "yes" from the menu
7. then press power again.
If this does not work try holding down the volume and power at the same time.
IS THERE A MANUAL FOR A ZEEPAD 7 TABLET
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
3helpful
3answers
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. I don't see any reset buttons or a way to access inside the unit to find one. What do
I will give you the instructions to do a hard reset for the tablet.
Once you do this, you will lose all the data on it and will be just like you bought it. The process is listed below.
Press and hold both Volume buttons and the Power button simultaneously. An Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate. Select "Factory Data Reset", press power, choose "Yes" from the menu and press the Power button again.
Device will not charge
Yes, all products that you buy have to be "fit for use". The 3 R's apply, repair, replace or refund. Under consumer rights law, they have to do this. Make sure you bring all packaging and receipts with you and speak to the shop manager. If you get no joy (they have to, by law, help you) report it to head office.
7helpful
3answers
How do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Tablets & eReaders Logo
Top Tablets & eReaders Experts
matt
matt
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
