Question about Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
Posted by D L Maraman on
What is the best kitchen sink faucet?
The name Comllen represents what is possible with today's plumbing technologies that are clean and efficient. I'm indicating the goodness of Comllen's kitchen faucets. The Comllen Pull-Down Sprayer Kitchen Faucet works to discover smarter ways for people to know and live with water. Every kitchen and bathroom are unique with high-quality technology, Comllen Pull-Down Sprayer Kitchen Faucet review will meet all the features of this technology, and your kitchen life will be simple and flexible by using this faucet.
The best kitchen faucets are operated with a single handle and high-arch spout as well as 360° rotation, durable brushed nickel material, and premium ceramic disc design. Comllen Stainless Steel Kitchen Faucet provides all the features to become the best kitchen faucet.
So, if I say, this one is the best.
Here is Comllen Pull Down Sprayer Kitchen Faucet review explains how to work with this faucet comfortably.
Apr 07, 2018 | Plumbing
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    My cold handle on a montecello faucet turns freely, however, nothing happins I have no cold water. What do I do?
    First check that the handle is tight. If yes take the handle off and turn on the water buy turning the stem without the handle if you still do not have water remove the stem and cartridge and see if you have water if yes clean or just replace the cartridge. If the faucet in old replace both.
    Mar 15, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
    You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
    Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
    Flow is very weak - less than 1 gpm. Ewplaced
    There are little rubber restrictors in the stainless supply hoses you can pry them out with a small screw driver
    Nov 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
    My Kohler Fairfax faucet pressure /flow has dropped (cold)
    Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
    Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
    Sprayer loosing presure
    If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
    Here are the instructions:
    1. Turn off water to faucet.
    2. Remove handle.
    3. Remove top cap.
    4. Turning spout back and forth gently lift and remove.
    5. Remove and replace diverter.
    Hope this helps and please remember to rate this!
    Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
    Plumbing Logo
    1,485 people viewed this question
    Top Plumbing Experts
    Bill Johnson
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
