Hello Dondrake, thank you for your submission!
From the information you have provided your Frigidaire dryer was knocking and now it is no longer heating. This could be a potential problem within your heating element or control panel. I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord from the dryer for at least ten minutes. I hope this information is helpful to your repair. -Matt
SOURCE: knocking sound in dryer
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like one of the 3 wheels that the drum turns on has a to be replaced.
It's stuck or hanging up!!!
For this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
SOURCE: Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
SOURCE: kenmore dryer is making a loud knocking sound but
ONE OF THE DRUM OR BOTH ROLLER WHEELS IS BAD-MIKE
SOURCE: dryer making knocking sound
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
SOURCE: My dryer starting knocking, it knocks loud then
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Here
It will help
Dryer
Repair Squeaks,
heatman101
Asker's
Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
