Question about Canon Elura 100 Mini DV Digital Camcorder
I have a Canon Elura 100 and I want to record from the SD card, but it says the recorder is off. How can I record on my card? Thanks.
I followed directions from the instructions, inserted my memory card, hit record, and it says the recorder is off. How can I record on my SD/memory card?
5 Suggested Answers
eagle338
eagle338
  • 4889 Answers
SOURCE: Transferring video footage from a Canon MV830i to a laptop
Here's the driver..Connect the camcoder to computer and then install the driver..you can find it here..
http://software.canon-europe.com/products/0010209.asp
Also you might want to buy a firewire card if you want to transfer a footage without any hickups..
Posted on Nov 02, 2007
Anonymous
SOURCE: Disabling the Auto-Off Power Function on Canon Elura Camcorder in Record Mode
Take the tape out. The Camera should stay on.
Posted on Apr 18, 2008
Anonymous
SOURCE: My Canon NTSC ZR70MC only records 30 seconds???
hola
Posted on Apr 27, 2008
Anonymous
SOURCE: Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Posted on Jul 08, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Posted on Nov 12, 2009
I bought a 16GB sandisk sdhc card for my Cnaon Elura 100. It says card error and will not initialize. What next?
Your camera is designed to use SD cards, not SDHC cards which are a later evolution of the SD card with different technical standards.
Your fix is to either stick with mini DV tapes or with SD cards with a maximum 2GB capacity.
Jun 30, 2010 | Canon Elura 100 Mini DV Digital Camcorder
What cable is required to download the recorded video on tape?
To download from the tape (not the memory card) you need a firewire cable, and a computer that has firewire compatibility. Most laptops have this, but desktops may require a firewire card to be installed.
May 05, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Camera won't record
Hi!
First of all, English is not my natural language, so please forgive me. My canon elura 100, bought in the US 1 year ago, had the same problem. After a big fall (from a second floor), the camera landed in wet sand and after that the camera won't record again (it plays the recorded files just ok). Just today i had the time to check the camera, so i disassemble the camera and found a poorly connected cable, that goes from from the lens body to the motherboard of the camera. After reconnecting this cable the camera start recording again.
regards
May 18, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Card error cassette error
A common fault, take it back to the shop!
Dec 25, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Dec 18, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Remove The Casette Message
THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
I suggest that no body buys from cannon again!!
I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
"TEMP. FIX"
This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
P.s- I hate CANON
Sep 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Elura 50 record direct to SD card
There may be a YouTube video that will help with this
Jun 30, 2017 | Canon Elura 50 Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
136 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
