Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 wont copy
Kodak 5100 printer will not copy. I can print and scan, but it will not copy a page I need.
Posted by Noelle Faulkner on
5 Related Answers
Anonymous
SOURCE: Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Posted on Jul 05, 2008
Anonymous
SOURCE: My Kodak 5100 Easyshare printer will not scan or copy
Call the Kodak customer service number and tell them that you need a new printhead, that's the device that your cartridges fit into.  They know that they have a problem but they will ask you to print a test sheet anyway.  They should ship you a new printhead within about five days - at no cost.  The printhead only seems to last about 4-6 months with my occasional use.  Tell them that they should replace the ink cartridges since you used probably used up the ones in the printer trying to do the diagnostics of cleaning the printhead.  They may not replace the cartridges but we should give them a hard time since it's their problem.
Posted on Mar 20, 2009
Anonymous
SOURCE: Kodak 5100 won't print with Windows 7.
I've had the same problem for some time, but recently found a fix. Those sneaky folks at Kodak updated their Vista driver for the ESP series, and it works with Windows 7 now. Oddly enough they haven't advertised this fact, but it works none-the-less. Now, you're going to have to uninstall the Kodak Home Center, the driver and anything else associated with Kodak. You need to manually go through the Program Folder and delete anything Kodak. Make sure you set explorer to show hidden files/directories, and go to Program Data and delete any thing Kodak. Finally go to users appdata and delete anything Kodak in all the sub folders there. Then download and install the new May 1 drivers from the Kodak site:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/13657/13660&product=EKN035329
Note: They are the Windows Vista drivers, but they do work on my Windows 7 machine.
You'll also notice that they've updated their installer program.
Hope this works for you, and if it does spread the word!
Posted on May 24, 2009
tweekgeek
  • 60 Answers
SOURCE: KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Posted on Jun 27, 2009
amir j zarou
  • 9 Answers
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
just remove the head printer and wash with warm water and lett.t dry and replace.t
Posted on Jan 20, 2010
Only prints blue
Try to press Photo and copy button at the same time to test the printer. It should print a demo page. Now if this demo page will print blue heres the step you need to Do
-If you computer connected to your computer launch your Home center software. Now on the upper right corner click the Help Icon(?) then look for maintenance and click the clean printhead do it 2x.
-try to reseat you ink cartridges
-If this issue wont resolve call kodak tol free 1 800 421 6699 and request for a printhead replacement
Nov 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
While trying to copy a letter on a kodak 5100 easyshare the page prints out with a yellow strip about 2 inches wide down the entire right side length of the page . Why is it doing this?
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer prints and copies but doesn,t scan
scanning requires a place to keep a copy of the document.connect ur computer and printer via usb2.0 and then open kodak home center from ur desktop. from there scan the document. u will be able to scan and keep a copy of the document on the desktop. if there is any problem,contact kodak @ 1800 421 6699
Jul 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black ink is faded or doesn't print at all
Once installed, Kodak All-in-One printer Home Center software allows you to print, copy, scan, and configure your All-in-One printer from your Windows XP or Vista computer.
To open the Home Center software window on your computer, use the Home Center icon on the Desktop or in the Start Menu
From the All-in-One printer Home Center main menu, selecting one of the six menu items enables you to:
  • Scan pictures and documents
  • Enhance and copy pictures
  • Enhance and print images
  • Configure settings for printing, copying, and scanning from the control panel
  • Access the Kodak Tips and Projects Center Web site.
  • Order supplies from the Kodak Web site.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Wont print
To solve your Issue, you need to clean install
the program, but to do that you need to call Kodak Technical
Support to guide you through the process... ^_^
Nov 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Easyshare 5100 not printing on correct side of paper
Load a single 8x10 page and press Copy + Cancel until the printer feeds the paper. It will spit it out blank. Try printing another photo. Make sure Kodak logo faces up when you load it
Jul 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-421-6699cb_transparent_r.gif.
Jun 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
71 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
