Question about RCA Televison & Video
Where can I get a cracked t.v. screen fixed, in Chgo. IL
Posted by Janice Fischer on
What is causing the grinding noise with my Il Gelateo Super?
I have an old Simac as well , & the same trouble , grinding in a surging sound,, we opened the trhtings, the moto is good, but the base has been broken . It looks like a star shaped cage for the motor, not centralized , causeign the gear to crack & eventually to go. I am looking for the spare part as well. Will let you know . PS the newee version is 4050 il gelato Magnum. Mine is Il Gelato 2380.
Mar 14, 2012 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
My laptop is a T60. Blank Screen
Moi j'ai presque le meme probleme apar que quand j'allume mon pc portable lenovo il me mais sur ?cran noir : lenovo idea pad VGA in no signal VO12
Pourtant il n'y a rien de branch? apar le cable de batterie du pc
Feb 03, 2010 | Lenovo ThinkPad T61 Notebook
Driver seat frame is cracked. I need to have it welded or ? Palatine, IL. area
probably easier to replace it than to have it fixed, to weld you must remove the seat from car then remove the cloth and padding so it does not burn.
Aug 12, 2009 | Cadillac DeVille Cars & Trucks
92 jeep wrangler, winter in chgo, will not allow push, trans?
i found in my jeep the parking brake likes to freeze on in cold weather other than that it sounds like it could be tranny transfercase or axels seized
Dec 28, 2008 | 1992 Jeep Wrangler
N70
(First: copy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen release all buttons. I hope this can assist you in the fix .
Sep 07, 2008 | Nokia N70 Cellular Phone
Depanage
am lokang for mamsung ltn 160at01 samsung 16.0 wxga lcd screen
Aug 27, 2008 | Acer Aspire 3100-1405 Notebook
Tape drags toward end of reel
Unplug the unit.
You probably have a brake band thet keeps the reel from free spinning. It's located under the top cover plate of the tape recorder. The band is made of cork. Over the years, it probably just got a buildup of dirt. It can be cleaned off with rubbing alcohol. Don't pull on it, it will snap. The piece you are looking for will be located right under the left reel post.
Jul 19, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
