Question about Apple iPad 4th generation
Remove iCloud lock from iPad
How to unlock iCloud locked iPad 4
Posted by Durga Karki on
Andrew Taylor
    Top Expert:
  • Apple Master
  • 33,126 Answers
I am not aware of an ' iCloud Lock '. If you mean the user set passcode, the only way is to do a Factory Reset.
iCloud has a password, and that is the same one you use at the App Store. That has to remain in place to protect your credit card use. If you have forgotten that password, you can click Forgot Password link and a reset will be emailed to the email address associated with your iCloud/iStore account.
Posted on May 03, 2016
Testimonial: "When i bought this iPad, it was already icloud locked. Im trying to have it iCloud unlocked. can you help me with it?"
  • 3 more comments
  • Andrew Taylor
    Andrew Taylor May 03, 2016
    Oh, so it is a stolen iPad and has been locked by the previous owner that lost it?
    I am not sure if a Factory Reset will clear it. It maybe that the firmware inside the iPad is permanently locked. If it as under a contract from a cellphone provider and is undischarged, it will also be blacklisted.
  • John Bausch
    John Bausch Apr 10, 2017
    Depending on the model of the iCloud locked iPad or iPod, there is a way to remove it, and it will set it to out of box state, however, it requires you to open the device and cross a couple of pins, sorry iPhone users, it only works on iPod's and iPad. What pins to cross depends on the model of the IDevices. Provide a model and I will provide the step by step guide
  • Ferdy Hooper
    Ferdy Hooper May 01, 2017
    How about model A1458? which pins to cross. NavyExchange could not go back to the date we purchased the ipad 4 back in January 2013 to show proof of purchase to Apple, Apple wants a receipt that shows the serial number. We paid $25 dollars to our bank to show bank account purchase but that didn't show the serial number so that wasn't good enough. I reset the ipad to factory settings but it didn't clear the iCloud. My mom forgot the info used to set-up the iCloud. She didn't know how the iCloud works so a friend set it up for her and that friend can no longer be reached after 2 years it was set-up. Please help. I have an iPad that cannot get to desktop and it still works great, don't even have visible scratches due to LifeProof case from day 1. Thank you for the help in advanced.
  • Andrew Taylor
    Andrew Taylor May 10, 2017
    This shows how to do an iCloud DNS Bypass which makes everything work. There are other videos also showing different ways. Sorry for delay I have been on vacation to the UK.
    https://www.youtube.com/watch?v=p35vKtPe...
  • Andrew Taylor
    and this was the page I found that. There are many links.
    https://www.google.ca/search?q=iCloud+Lo...
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
Nov 12, 2017 | Tablets & eReaders
Remove activation lock on IPad Person who had the IPad is deceased
If it white screen you are screwed if you do not no the Apple ID
if you can access the screen you can google check Apple ID then type the serial number to heck if it iCloud lock you can find serial number or imei number back of the iPad or in sim try if it's 3G iPad then type in and see if the iCloud is locked or not if it's not you can restore Ipad by iTunes on your computer turning the iPad off by pressing holding the power button and in-certain the charge till iTunes logo pop up on your iPad and then on your computer then restore the iPad
Mar 29, 2017 | Apple iPad Tablets & eReaders
I want to remove icloud activation from my ipad
Steps to delete iCloud account on iPhone/iPad
  1. Tap on the Settings app and then scroll down to find iCloud.
  2. Tap on "iCloud" to open it.
  3. Scroll down until you find "Delete Account" and then tap on that.
  4. Tap on "Delete" again to confirm the deletion of the iCloud account.
Mar 25, 2017 | Apple iPad Tablets & eReaders
If i bought a iPad but its iCloud locked and erased how can I unlock it or do I just have to go to the apple store.
icloud locked is a personal security code not apples and apple will not be able to help you what you bought is a parts ipad
Sep 09, 2016 | Apple iPad Mini
Over ride reset
Hi there, the is no official supported way to unlock an iCloud locked device beside using the password or resetting it(via apple process), many 3rd part site boast about being able to do so however I do not have first hand knowledge that they are successful. I am so confident in the fact that you will not be able to remove the iCloud lock that I would be will to say "you can't" but anything is possible. You can sell the device for parts. Sorry I am not able to offer you more help.
Thanks and good luck
Questions? Just ask
Mr.Mike
Mar 23, 2016 | Apple Tablets & eReaders
How can I activate an iPad mini that is iCloud locked
I would go to an Apple Store and ask for help.
kolbrun
Dec 22, 2014 | iPad mini Tablets & eReaders
Apple iPad 4th generation Logo
480 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
