Hi sim lock code is nothing but your Samsung U600 mobile is locked to one particular network provider .Due to this it wont accept other network sim in it .To solve this you must unlock it .Code are the best solution to unlock it .To purchase code visit Theunlockarena.com here you need to specify the network name to which your mobile is locked and the IMEI number of your mobile .Then they render you code to unlock your mobile.
hi codes are the best method to unlock the simlock in your mobile .to purchase codes visit superunlockcodes.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock your mobile.
Sim lock cannot be unlocked using the default code or some code typing in Mobile....Where you get the Unlock code.? You can get the unlock code from service provider or from Online sites and unlock it...You can get the unlock code or Sim Unlock code from for samsung E250I at here Theunlockarena.com/unlock-your-phone/rs13wp2/ and Unlock it...Sim Unlock and Network Unlock are same.
Did you forgot the procedure to SIMLOCK you Samsung S3653 or did you forgot your phone lock code?? if you want to simlock your mobile then you can do it by unlock codes and for codes try Simpleunlocking and get your mobile unlocked from network and if you want security code try to reset your mobile..
hi you can use codes to remove the simlock in your samsung b130 mobile .you can get the codes from this site wickedunlock here they ask the imei number of the mobile .finally they will send you the codes to unlock your mobile.
You can remove your simlock using the code. Get the unlocking service from Classicunlocking.com . Here i found an unlocking solution for your mobile at cheap price.Through this you can unlock your mobile easily.
hi you can use codes to remove the simlock in your mobile .you can get the codes from this site simpleunlocking here they render codes for all mobile models along with instructions about how to use the codes in your mobile.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved OR: If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
I think you have a Network locked. You can check on Ebay to buy an unlocked code. The seller will provide you the code with instruction of how to unlock it. You should prepare your phone IMEI number to give to the seller in order to get a proper code. In order to know your phone IMEI number, just type *#06# Good Luck
