My device is showing meters and I want it in yards. How do I change that?
Buddy VS4 has this bug. You don't need to worry about it and I'll suggest you not to buy golf gps before checking their reviews online.
If you want to check reviews, this is the best reviews site (https://ourrangefinder.com/best-golf-gps-rangefinders/) I ever found.
Posted on Dec 18, 2021
SOURCE: Changing Modes
press the power button to turn the unit on then, while looking through the monocular, press and hold the mode button for 5 seconds. You will see the unit of measure indicator switch from meters to yards. Good Luck!
Posted on Apr 15, 2007
SOURCE: How do I change Meters to Yards
with unit on- hold mode button down for five seconds
Posted on Jan 27, 2009
SOURCE: Meters to Yards
If the unit has a "mode" button, hold it down for at least 5 seconds and see if the "Y" comes up on the screen. Let me know if that helped...mtg
Posted on Apr 11, 2009
SOURCE: change my golf buddy from metric to yards.
It should be noted that the GolfBuddy GPS is preset to yards. If you or someone else accidentally changed it to metrics and are wondering how to set it back to yards, here's what you need to do.
First, you need to access the Play Golf Menu by pressing and holding the OK button for 2 seconds. Scroll through the selections using the arrow buttons, until you reach the Y/M selection. Press and hold the Plus button on this menu option to change between metrics and yards. Make sure to set your units correctly before playing and test if the device is properly functioning to avoid interruptions.
Having a GPS handy whenever you play can greatly speed up and improve your game. Check out golf GPS reviews to find the most compatible device for your needs.
Posted on Apr 26, 2018
