Televison & Video Logo
Question about Philips Televison & Video
Hi all could someone help me please I have a philips 42pfp5532d and its stuck in digital tv and when I press menu nothing comes on the screen . What do I need to do ??
Posted by chris williams on
Charles Houlroyd
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Search or call Phillips and see how to reset the TV back to the factory settings. Sometimes its as easy as hitting a couple of keys on your remote. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Posted on May 02, 2016
5 Related Answers
Anonymous
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
Anonymous
SOURCE: viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Posted on Jan 04, 2008
Anonymous
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
Anonymous
  • 197 Answers
SOURCE: I have a Philips 42PF7320A. The menu is stuck on
try softwear update if not ssp pcb call phillips for soft wear
Posted on Jun 09, 2009
Anonymous
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
2answers
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
6helpful
How to reset my Tv Plasa Philips model 42PFP5532D to factory (hard reset) ?
To reset to the factory default settings, press and hold down the MENU key on the side of the TV set for 5 seconds. A menu will appear on the screen with language and etc. If you want to, set everything like it was your first time with the tv.
2helpful
2answers
Philips 42PFP5532D/ MAKES THE NORMAL CLICKING NOISE WHEN YOU TURN IT ON . BUT IT CLICKS BACK OF AGAIN SO YOU DONT EVEN GET A PICTURE ALL YOU GET IS THE RED STANDBYE LIGHT FLASHING DO YOU NO WHAT THE...
philips tv's test them selves when turned on if something is wrong it shuts down you need a tech to determine your problem more than likely it is you power supply
8helpful
2answers
Digital channels have stopped working, only blue screen!
Child Locked TV and Remote
Press MENU to show the on-screen
menu.
Press VOL+ or VOL- to highlight SET.
Press CH+ or CH- to highlight
PARENTAL CONTROL.
Press VOL+ or VOL- to display the
SECRET CODE
screen.
Press VOL+ (on the remote) and the
CH+ button on the front of the TV
at the same time.
Press the Number buttons to
enter a four-digit code. The code will
appear on the screen as you enter it.
The code "0000" is the default of the
TV. If you have not set up a code previously,
then "0000" is the code.You cannot
use "0000" after you set your own
code (unless you reset the code to
"0000").
Press MENU to save the code.
Hope this helps. :}
HERE IS A LINK TO THE USER MANUAL:
http://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
2helpful
Phillips 15pt6807/05
Hi, EASY :) just a few clicks on Google...... Turn the TV on, press the number 9 on the remote four times (9999) an then press MENU button on the remote too. Thtas all folks !, Sorry for my bad English but I'm from Spain :)
Good luck ;)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=14PT6007/05&slg=ENG&grp=TV_GR&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU#
2answers
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
