Hooked up to projector and cable box with HDMI.flashing video.
I have sound, and steady HDMI red light, but video flashes on then fuzz then blank, repeat. Tried changing settings to lower resolution, no change, tried reset, tried using different inputs, no Change.
Is your TV connected to a Set Top Box (Cable TV box?).
If so, then you will get blank screen until that box is powered on. Secondly, you could check the cable (usually HDMI cable) between the SetTop Box and the TV..
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present. Just an idea?
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
