Toshiba hdmi ports not working
Hey guys, thanks for your time, I have a 52lx177 regza cinema series television and am having major problems with the hdmi imputs not reading the hdmi cables at all or just for a little while and then dropping the signal entirely and me having to reset everything to get a signal just for the damn thing to do it again! I thought that it might be my direct tv hddvr box, which is why I have gone through 5 of them in the past 6 weeks, finally I decided to just keep my component cables hooked up to the tv and hddvr box instead because nothing is being brodcast in 1080 p on television anyway. Well guess what happened when I finally bought a ps3 and tried to start watching movies, THE SAME THING! Everything is fine for a very short period of time and then bam, the signal goes out and the tv says no video signal. If I turn everything off and disconnect the hdmi cable from the tv and then reconnect it I get picture again and things are fine but not for very long before the same thing happens again and again and again. I have tried over 5 different hdmi cables with both pieces of equipment so I know its not the cables. Listen, I love toshiba but if I cant get this problem fixed and soon I will never even look at their brand name ever again! I spent with warrenty almst 5,000. and to be going through this hell sickens me right now! Please help me with this, I am at the end of my patience and have lost enough time, money, sleep, and piece of mind. I thank you and look forward to talking to you very soon. chris grossnickle
Posted by chrisG on
  • chrisG Nov 18, 2007
    hey guys, thanks for your time, I have a 52lx177 regza cinema series television and am having major problems with the hdmi imputs not reading the hdmi cables at all or just for a little while and then dropping the signal entirely and me having to reset everything to get a signal just for the damn thing to do it again! I thought that it might be my direct tv hddvr box, which is why I have gone through 5 of them in the past 6 weeks, finally I decided to just keep my component cables hooked up to the tv and hddvr box instead because nothing is being brodcast in 1080 p on television anyway. Well guess what happened when I finally bought a ps3 and tried to start watching movies, THE SAME THING! Everything is fine for a very short period of time and then bam, the signal goes out and the tv says no video signal. If I turn everything off and disconnect the hdmi cable from the tv and then reconnect it I get picture again and things are fine but not for very long before the same thing happens again and again and again. I have tried over 5 different hdmi cables with both pieces of equipment so I know its not the cables. Listen, I love toshiba but if I cant get this problem fixed and soon I will never even look at their brand name ever again! I spent with warrenty almst 5,000. and to be going through this hell sickens me right now! Please help me with this, I am at the end of my patience and have lost enough time, money, sleep, and piece of mind. I thank you and look forward to talking to you very soon. chris grossnickle
paul proctor
  • 4,102 Answers
This is deffinately either a bad solder on the hdmi connector socket or the one problem most people get is a overheating problem it seems with this make of tv its not upto the heat it produces when you are usin hdmi what i would do is demand for replacement telly which could have same problem on it as this is common fault with this set or if you want to get the solder checked out take to repair shop but the only problem doing this it will void any warranty ass the telly will have been taken apart so i suggest take it back and get replacement because if it is just solder problem and you get somebody to do it for you then if anything else goes wrong your warranty will be void you could try getting them to do the work under the warranty agreement this way you will be covered if anything else goes wrong if you have already took the tv apart ie removed cases then check if it has a fan and it is working fine but if the hdmi works for a short while and the wires are not getting moved or knocked during use then the problem is deffinately a overheating problem maybe they might fit an uprated fan to overcome this prob if it was me i would get replacement tv under warranty and try againg but if you have same problem then you know it is common fault on this set but i have noticed alot of these sets coming through the repair shops with the same prob must be a manufacture prob sorry couldnt be anymore help i would hassle supplier and demand replacement........................
Posted on Nov 19, 2007
Trinity Sabre
    Novelist:
  • 111 Answers
If you have spent almost 5000 on the warranty and it was for the same issue, i would notify them that the problem is not resolved and demand that they fix it for free or provide a replacement. this sounds like either the hdmi input connector is badly soldered, or the hdmi signal board is going out or overheating. if your tv has a fan for that area, insure that it is working.
Posted on Nov 18, 2007
  • Trinity Sabre
    Trinity Sabre Nov 18, 2007
    as a sidenote, have you tried the firmware update yet? if not, the toshiba service center closest to you shoudl do the firmware update for free or cheap, and it seems to fix a load of hdmi problems.
  • Trinity Sabre
    Trinity Sabre Nov 19, 2007
    i did a little more research and found thathttp://fixyourowntv.com/firmwareupgrade....
    may have your firmware upgrade if you want to try it yourself, you will have to email them as your specific model is not listed.
1 Related Answer
Anonymous
SOURCE: toshiba hdmi ports not working
I talked to Toshiba about his problem, this morning. They said they have never hear of such an issue. I told them the TV was less than 1 week old, and would hope Toshiba would do something in response to my alternative action of returning both my Toshiba HD DVD and 52LX177 for a new brand. They said all they can do is have me go to a service center for them to repair it. 1 week old TV and DVD, $4000, for repair; I don't think so. I talked to two different people a Toshiba regarding this, with the same answer. Very poor customer support, especially for a higher end product like this. I think I have no choice but to change brands.
Posted on Jan 04, 2008
I own a toshiba Regza 46rv530u and have owned it for about 2 years. Never had any problems until right now! None of my hdmi ports are working. I have not changed any settings on the tv or my game consoles....
Hello
Check your TV for other inputs, ie, AV, antenna etc. If these inputs are working fine, and only HDMI has the trouble, check the HDMI cable. Reset the TV to its original factory settings according to its manual says. Check these and inform me if you fails to get the HDMI input. OK.
Sep 28, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Nov 20, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
REGZA 42HL167 Won't turn on
I found it!!
In my case, the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
I agree -- it seems like a design flaw. What cracks me up is that the places I called for a replacement SEINE PCB require the core (the bad PCB). Well GEE, why is that!?!? EASY FIX MAYBE?
It was. Too easy. Shamefully easy.
-Ben
Aug 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
PC DVI to HDMI Regza Connection
I'm getting the same problem with an ATI Radeon HD 2400 going to a Regza AV555D on HDMI 1. In order to get the picture back I have to call up the source menu and move down to HDMI 2 (without clicking OK, just hover) and wait for the screen to change. Then go back to HDMI 1 for a few seconds until it flickers and then press OK. A bit long winded and far from a solution but it's enough to sync it all back together again
Apr 22, 2008 | Televison & Video
Nov 18, 2007 | Televison & Video
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
