Video Cameras Logo
Lucas Koerner Posted on May 01, 2016
Not pairing - Video Cameras
What is the slot access capacity on OSN 7500?
OSN7500 slot access capacity is different when equip with different Cross-Connect Board Huawei osn 7500 MSTP transmission sytem Thunder link com
Sm-g31or5 want to pair with my 07 toyota solara convertible. phone says paired, but not car
Just had to pair for a friend few days ago, Toyou press setupota will pair to audio, but not hands free talk. Not sure exactly what buttons to push on your particular, so I would suggest read your car manual for "Hands Free Bluetooth" Pairing, not just audio pairing. On Toyota that I paired, after you press setup Bluetooth you will have to press "Phone Off" button on your steering wheel to get into hands free pairing, but check your manual to be sure.
1helpful
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
b) When the headset enters Pairing Mode, the LED indicator will show a solid
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 • Home
Power Pair
It doesn't have one. The voice pair (3+4 or 4+5 on an 8-pin jack) has 24 volts DC and the data pair less, but the power to run the phone comes from both pairs, or more probably from the voice pair.
Carl
1helpful
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 • Cell Phones
1helpful
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps...
1helpful
I need pass key for Jabra BT530 to pair with cell phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 06, 2010 • Cell Phones
How to put a hbh705 into pairing mode
Take care.
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
