Question about HP Pavilion dv6000z Notebook
It doesnt charge or turn on how to factory reset
Posted by Jeffrey Allen on
My samsung galaxy mega wont charge. Ive had it for maybe a month. It charged fine before I went to work then I got home and nothing. When I turn off the phone the samsung logo shows up but instead of being...
IF you have had it for a month and you bought it new, take it back, it is a warranty issue. If not then you are looking at a possible service issue on the charging board or the main board.
Aug 19, 2017 • Cell Phones
2answers
Sylvania SmartBook
Try to reset to factory settings & update to current drivers.
How do I hard reset this phone
First remove your sim and SD card if you have one.You lose everything after a hard reset,so back up your contacts to your sim card first if you have them installed on your devices memory only.Also make sure your battery is charged.
Then you will have to enter the factory settings menu by dialing 338464#*# , or if this doesnt work for you dial 277634#*# .
4helpful
2answers
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
How to reset phone
try to charge ur battery. if problem persist change ur battery
Original owner of my daytona 650, Ive been riding all day, sitting at a stop light, if my fan kicks on my gauges reset as if i just turned on the key and sometimes my speedometer doesnt work after the...
The rectifier that is within the charging/electrical system sounds like it is gone.It may not be , but from what you posted,it seems like it.Hope this helps
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
3answers
I can't reset my cwr-854 router by pressing the RESET button for more than 1 minute and nthing happens , either in Power ON and OFF
You can reset this Wireless Access Point by clicking on Reset button, and then press OK button to confirm your decision.
Note: you can also hold down the reset button for more than 10 seconds to reset its default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
2answers
ARGHHHH!!!! my nokia 2630 is just gone. i bought it 2 days ago, and it has just gone blank, i've tried turning it on and off and still doesnt work! please help me!
remove the battery for 10 minutes, then put it back and charge ur phone for 8 hours. turn on the phone only after that,
If the phone turn on when u charge, that's ok, continue charging
My phone is all out of whack
Well maybe your sim has been cancelled or blocked or even out of date , thats what hapened to mine ( one of them lol ) so you can order free sim cards of all kinds on the internet i suggest you do that 1st and then your network should be fully functioning , after that try reset your factory settings which can be accessed via the settings icon , then select restore factory settings the code should be 1234 or 12345 , that should fix your date problem , and for your charging problem try a new battery becoz if your battery was removed and then when u put it back in it doesnt charge then there must be a fault with your battery , hope i helped :D
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
