Feb 26, 2018 - Mitsubishi Magna & Verada PDF Workshop and Repair manuals, Wiring ... supplemented by a luxury version called Mitsubishi Verada with a V6 engine. ... series in 1996, the all-wheel drive (AWD) version was added in 2002.
When the ABS light stays on it means that the computer control module has sensed a fault and it has turned off the ABS and turned the light on to alert you to the problem. You need it tested for fault codes with a special scan tool.
not sure what you wont to know but the sender will be mostlikly near the oil filter,with ignition on short the wire and the oil pressure gauge will read high or oil pressure light will go off youll know you have the wright sender
they just pop in on the mits model remove the neccesary bolts and **** it out one at a time though dont take both out or youll need a new trans to to put it back it firmly pop it in
you open up the hood of the car or as it is called bonnet and you go to the back of the headlight there shold be screws there and you open the and simply pull out the cover and pull out the bulb
