Sanyo  42 in. LCD TV Logo
Linda Cartmell Posted on Apr 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get any sound on the TVs at all - Sanyo 42 in. LCD TV
  • kkirkpatrick baker
    kkirkpatrick baker Apr 29, 2016
    see my other answer all remotes and tv must have proper codes to work
kkirkpatrick baker
Level 2:
Sergeant:
  • Expert 313 Answers
  • Posted on Apr 29, 2016
kkirkpatrick baker
Expert
Level 2:
Sergeant:
Answers
313
Questions
Helped
83244
Points
637
Think u have menu on control unit turn sound back on some how it has been turned off
Testimonial: "Still no joy have lost the original remote so I have bought a universal remote control have managed to connect it to the TVs but I can not get any sound on at all"
    linda find your code for the new remote than enter it and sound will return the code is what you need for that remote ask sanyo for it
I have a 40,and two 32 inch tvs on my rv and they seemed to be froze up ,i cannot get the menu to work on all three tvs
Sounds like you might be using a universal remote. Use the remotes the tvs came with. If you are, unplug the tvs for 24hrs.
1helpful
2answers
Hoe to open seat cover tvs star city 110 model 2009
I suggest you to go to this link to know details about this .... TVS Archives Motorcycle Priceinbd Info
1helpful
How do you turn audio on?????
This can be found found from your TVs remote ,there is switch for sound.if your TVs mute option in ON ,it will not produce sound..you have to make mute off.
Sound not coming
Hello
You have reported that there is a sound problem for your TV. I don't know you have tried all the options in the sound menu of your TVs user manual, you haven't stated anyting about it. Anyway I assume that there was sound, and it has gone now only and send this solutiion.
Just connect the audio out socket on the rear of your tv, to any audio devices you have, an amplifier or so, and check whether cound comes from that device or not. If there is no sound from that device, it means that something has gone in trouble with your TVs sound filtering system, which is integrated on the printed circuit board inside and you must have skill and through knowledge about soldering, and to follow the circuit schematic digram.
If there is sound now through that device, means either your TVs speaker has damaged or its Sound Output Ic is damaged. If speaker is damaged, it can be easlyto replaced with an identical one. To make sure about it, you just place your ear very near to the speaker side of your TV, and switch ON it by AC MAINS. You will hear a small "Thumb" sound if your speakers are Ok. If there is no "Thumb" sound you can make sure that the speaker is damaged. If you hear a "Hum" sound, it means that your TVs Sound Output Ic has damaged.
You just check these, and report the result to me through Fixya. Since you have given a small description about your TVs fault; with two or three words, how can I get to the exact point of fault. Give me details as much as you can an you know. Ok.
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
3helpful
TVS Star City bike silencer busting sound
I am not expert but I have same problem when down accelerator.
It may occure due to current coil or Uro2 dirty. I clean the uro2 filter by the oil and no busting sound found after that.
I have an LG LED TV and Samsung 5.1 Surround sound and when it comes to Blu Ray movies I get sound, but I don't get the surround sound through cable or XBOX 360, the only time I do is through the TV when...
the very best and easiest solution is have every input into your tv, and your TVs audio out (RCA/Optical) into your reciever. this is a variable audio (Meaning you can only listen to your reciever with your TVs audio up) or you can turn off the audio completely in your TVs soiund properties.
hope that helped :) -Jordon
Dish network VIP722 DVR - cant get sound to pass thru TV
HDMI is digital sound. I don't know why it's not passing through. You could run a set of audio cables to the surround sound. The not a noticable difference in my opinion.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
