Question about Vizio E320i-A0 32 Class LED Smart TV
Vizio e320i-a0 that flicker constantly
It's dim but can still see picture then gets dark but comes and goes flickers or strobes constantly
Posted by Tim Johnson on
Electro Med Services
  • Vizio Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Apr 29, 2016
5 Related Answers
SALMAN NASEER
  • 1011 Answers
SOURCE: my tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Posted on Jul 29, 2008
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: vizio television screen flickers like a strobe
lcd sets use florescent tubes to light the display and, a ballast to power the tubes just like the lights in an office ceiling.
the tubes are called cold cathodes and, the ballasts are called inverter boards. replace your inverter circuit board it connects by wires to the cold cathodes so; isn't hard to find.
Posted on Oct 05, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Flickering problem with Tv.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
PARTS: http://www.shopjimmy.com/catalogsearch/result/?q=vizio+l32
Please post back what you find.
Posted on Dec 17, 2009
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
Prof  Henry
Ikenye Henry
  • 209 Answers
SOURCE: My Vizio 37inch is 4
It needs servicing. take it to a technician.
Posted on Aug 11, 2011
I have a Vizio e320i-a0 tv with a flickering picture
Buy a new TV...chances are its a bad panel if you replaced all the boards
Jan 15, 2018 | Vizio Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Vizio TV has sound but no picture
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
My screen is flickering on and off on Vizio LCD TV? I was wondering if it was the main board or the T-Con board.
Flickering can be either with the fault to its back-light inverter or with its main power supply regulator board.
Sep 25, 2015 | Vizio E320i-A0 32 Class LED Smart TV
My Vizio E320i-A0 tv, has barley any picture when i pug in and turn on, VERY faint logo on screen, How do I fix it?
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
3 . Highlight Yes and press OK.
4 .Press the EXIT button on the remote.
A manual is available here:
http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 17, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | Vizio 42 in. LCD TV
My tv picture is dark and flickers
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Vizio E320i-A0 32 Class LED Smart TV Logo
731 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
