The espresso comes out very slowly and the grounds are muddy and not very packed after brewing. We had an issue with the hot water valve not shutting off all the way a few days ago, now this. Is this lime?
SOURCE: Rancilio Epoca DE 2 group espresso machine
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
SOURCE: Rancilio Silvia Espresso water flows too quickly about 7 seconds
SOURCE: Rancilio Epoca S1. Constant click noise??
It is the sound of the pressure stat turning on and off, that is normal.
SOURCE: Diminished pressure when brewing espresso
try adjust grinder,try go litlle bit courser ,check screen it need to be clean.
SOURCE: Reduced flow of hot water through the coffee
Check screen and diffuser for blockage, backwash machine. If you still have the noise problem, when runnig the head, then it is block at the solenoid. For the temperature, it is possible that the one of the thermostat is damaged.
