Question about magicJack Plus
MJPlus-router notPC connected, can I pull up phone logs?
Posted by Jim Blyth on
Why I cant log on my account instead the phone kept on searching the hole time
It is maybe because of your internet connection. Try rebooting your router if you are using a WiFi. Turn it on again and connect your phone. Also, you can check your internet connection's speed at speedtest. Just search it in google :)
Sep 05, 2016 | Cell Phones
Magicjack troubleshooting
you need a usb power adapter .
Jan 25, 2014 | Computers & Internet
Wont connect to internet or phone blue light is on ,MJplus
Replace the network cable between the MJ+ and the router. Replace the cable from the MJ+ to the phone. If it still doesn't work, try a different phone. If that doesn't help, unplug the MJ+ from the router and phone, then use the USB to connect it to your computer and make sure the firmware on the device is fully up-to-date. Reset the router (just for giggles, to make SURE) THEN reconnect the MJ+ to the router the power supply, and the phone, and try to use it again. I hope this helps to solve your problem. I have one and it works great and has for over a year without issue.
Dec 08, 2013 | Computers & Internet
I have a 655 router.. running windows7 on one computer on Home Network.. Router initially working OK..computer connected via cat5 wire. Disconnected router, moved to new location on desk...reconnected...
You can reset both the modem and the router by removing the power cord where it connects into the router (Called Recycling the Power) I would do it with both the modem and the router for about a full 2 minutes.
Sounds more like you have a connectivity issue from interference from something on you desk. Some known culprits are:
High Intensity Lamps Fans Radio Interference coming from your wireless phone Power strip with filters for telephone signal any other environmental issues including computer monitor. Next door neighbor's router signal bleeding through. Filter device missing from phone Filter device missing from phone line connected to you TV
Try moving the router back to the old location. Does problem go away. You are now too close to something thats breaking your signal. I can log into my neighbors access point across the street and two houses away. Signals are strong but can be blocked by a lot of things mentioned above or tin foil.
Check it out,
TF
Jun 03, 2011 | D-Link DIR-655 Wireless Router
There is an internet connection but it will not connect, say Aquiring network connection
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Apr 09, 2011 | Zonet ZEW2545 IEEE 802.11b/g IEEE 802.11n...
I keep getting a popup saking you're connected to more than one network, please close all but the primary network
Your issue is due to the you having to routers active and the PC is connecting to both.
You will have to disable one of the connection in the main router for this occurrence to stop.
check you PC 's wireless connection and disable connectivity also to the secondary router.
7. Move the laptop about 20ft away and try to log on to the internet.
Oct 04, 2010 | Linksys WRT160N Wireless Router
The internet wont connect to mys dsi
status window)
through a browser.
router
Sep 20, 2010 | Computers & Internet
My belkin n1 vision router hang at least 3 times a week regularly, what wrong with it? I must pull out powercable and plug in again in 5 seconds will work again or sometimes it will automatic restart but...
Sep 08, 2010 | Belkin N1 Vision Router
Likely problems when working in woodworkshop
1.Log into router
7. Move the laptop about 20ft away from any cordless phone or TV sets and try to log on to the internet.
Aug 02, 2010 | Computers & Internet
magicJack Plus Logo
54 people viewed this question
Top magicJack Office Equipment & Supplies Experts
ray gallant
C. David Graves
Are you a magicJack Office Equipment and Supply Expert? Answer questions, earn points and help others
