According to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Testimonial: "One word,AWSOME!"
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
