Music Logo
Steven Hunt Posted on Apr 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 16 channel Yamaha mixer board will not power on as if power switch is messed up I'm wondering if there is an easy fix
Jhon Karls
Level 2:
Habit-Forming:
  • Expert 78 Answers
  • Posted on Oct 21, 2022
Jhon Karls
Expert
Level 2:
Habit-Forming:
Answers
78
Questions
Helped
29652
Points
253
New Holland My16 My17 My19 Yard Tractor Service Manual New Holland MY16, MY17, MY19 Mower Service ManualManual for: Mower MY16, MY17, MY19Format: PDFPart wide variety 87045362EnglishFebruary 2004 New Holland MY16, MY17, MY19 Mower Service Manual:
rhodesworks
Level 3:
Top Expert:
  • Yamaha Master 3,159 Answers
  • Posted on Apr 29, 2016
rhodesworks
Yamaha Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561508
Points
331463
It depends. If if has an external power supply, you can try a different supply of the same rating. Beyond that, it may be a blown fuse, which may be internal on the power supply board, or as you say perhaps a broken power switch. Whether it's easy or not will depend on your diagnostic skills, how much you know about electronic repairs, and your availability of parts.
Generally, i suggest people take their repairs to professionals as poking around inside electronic gear can cause more damage, both to the gear and to themselves.
1helpful
No audio from main speakon outputs A and B
Hi, I think in most amps switching to bridge mode simply means the amp supplies its total power through the left channel only. It's the best way to use all of your amp's power but nothing comes out of the right channel. Having speakers connected to both channels would simply mean that only the Left channel works, it would not blow it. Some amps have the speakers wired to binding posts and this varies according to whether you want mono, stereo or bridged. I can't help with the power board sorry
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 • Music
Aviom personal mixer disassembly
You have to very, very, VERY carefully apply even pressure to both sides of the button when you pry it off, keeping it centered the whole time. Any significant movement off center will break the tactile switch it covers on the circuit board.
One channel working and one not
Yep... failed channel... most likely "A" channel? There is weak insulation between two layers of conductors on the power amp circuit board that breaks down and blows out the switching transistors for that side... it is usually the rear-most amp. Repair of the board takes GREAT skill in restoring it as the burned area must be ground away and re-insulated and jumpers put in to replace the circuit that has to be removed. The blown components then have to be replaced. One can buy a new HCA2400 amp module for about $155, but delivery takes forever. Also please read my tip on Fixya regarding PMP Behinger powered mixers of a hazard when using Speakon to 1/4 inch speaker cables/adapters.
Channel 6 clip led on constantly.
Is the channel clipping or just the LED stuck on?
Should be an easy fix if its just the LED.
1helpful
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Connecting unpowered monitors to the board
You will need toput power amplifiers that drive the speakers and then connect the board to the power amps. Use BALANCED interconnects for this and power the board from the same receptacle or surce as the amps.
All channels are clipping after water spilled on mixer.
If power was NOT turned off immediately after the spill, it is likely electrolysis has eaten through one or more circuit trace(s). If power had been turned off right away and the unit dried it would have been OK. The unit will have to be taken to a shop and repaired. This could be an expensive repair.
If the mixer is working properly audio wise and only the clip LED's are lighting, the cost may be mostly labor to repair the circuit board damage.
I was trying to hook up our 1604 vlz3 at our church and was wondering how the best way to do this?
Without knowing the resources you are connecting I cannot give you a schematic but will give this GENERAL advice:
1. Use BALANCED lines to connect from the mixer to your amps, preferably XLR connections.
2. Service the power to the amps and the mixer from the SAME place even if it means stringing a power cable alongside you audio cable snake.
2answers
Europowre pmp 3000 a120v or 220v?
There is a jumper (JP1 or J1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. See the pictures about my project. :)
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
