Question about Chevrolet 1985 Chevrolet Blazer S10/jimmy S15 Radio
The ECU 1 FUSE BLOWS WHEN THE IGNITION IS TURNED ON
UNPLUGED THE MAP,INJECTORS,TPS,IAC,i could not find the fuel pump relay
Posted by ERIC STEWART on
5 Related Answers
motor1258
Mike Butler
  • 6674 Answers
SOURCE: fuel pump not staying on 1993 k1500 350
Some GM products also incorporate the oil sender switch into that circuit for fuel pump, so that in case of an accident, engine shuts off, oil pressure drops, in turn, shuts off power to fuel pump. May be worth a look at what your getting for oil pressure, as well as checking switch/sender.
Posted on Feb 13, 2009
Anonymous
  • 580 Answers
SOURCE: 92 chevy 1500 5.7 tbi starts and dies. replaced
Try using a good fuel line/injector cleaner Seafoam is a good one. If this does not help you may have tone or more clogged injectors. Clean these out and you should be good to go. tTo see Seafoam in action goto you tube type Seafoam into the search box.
Posted on Jul 08, 2009
Anonymous
  • 10 Answers
SOURCE: fuel injecter fuse blow imeditaly when ignition turn on
sounds like a short in the wiring from the fuse and the fuel injector junction block. GM like most fuel injection systems control injector firing by the computer providing ground to each injector in pairs or individually. The fuel injector fuse provides power to the injectors using splices therefore enabling one wire to feed 6 injectors. A shorted wire at any of these wires will blow the fuse. On one rare incident I found a faulty computer caused the fuse to blow. A shorted injector will just cause a rough running problem due to the injector stuck either open or closed.
Posted on Aug 05, 2009
Richard Scordino
  • 6982 Answers
SOURCE: 95 impala lt1 will stall when warm and not start
On the plus side, when you are finished, you will have a new control system! On the negative side, you just spent more money on parts than if you'd have just taken it to a dealer! I hope you tested those components and determined they have failed. Any codes?
Seems like the only thing you missed is the coil and the temp sending unit (just for laughs, unplug it and see if it stalls out at the same time), or possibly a security system malfunction. Get a decent volt/ohmeter and a vehicle specific manual such as chiltons or haynes. Do some testing, hot and cold and compare your results.You need to determine what is shutting down (fuel, spark or both) Once you develop a "picture" regarding what is happening, you will be more able to find a solution. I can't give you a "fix" on this one only because to properly identify the problem, I'd need to do the same testing I suggested.
good luck
Posted on Sep 03, 2009
robert wales
  • 4977 Answers
SOURCE: Fuel injector fuse is blown, keeps blowing. Engine turns but won't catch and start.
if the injector fuse is blown then the car won`t start as its not getting fuel into the motor to fire.if the fuse keeps blowing then you could have an injector/s that is drawing too much or the injector driver in the ecm may not be any good and needs replacing or a used ecm.it could be a short some where in the wiring for the injector system that is going to ground.
Posted on Feb 22, 2012
2004 Suzuki GSX-R 1000 will not start
Hi, Dawn since the GiPro is directly wired into your ECU and had a catastrophic meltdown it's possible it also fried your ECU. Since an ECU is very expensive you should have the suspect unit tested, re-mapped, or repaired if possible otherwise the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
17. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
18. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
19. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
20. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
21. Faulty neutral, clutch, kickstand safety switch.
22. Faulty fuel pump or fuse or relay.
23. Faulty or corroded run/stop switch.
24. Tilt sensor needs a reset.
25. Security system not disarming alarm needs a reset.
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GiPro ATRE from HealTech
http://ecumeistro.com/category/suzuki
Suzuki GSX R1000 Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
Suzuki GSX R1000 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 08, 2018 | 2004 Suzuki GSX-R 1000
I unplug my stator to voltage regulator as directed to run test on stator then asks to start bike. bike turns over but will not start , why
Hi, David and the usual suspects are:
1. Fuel tank empty.
6. Engine flooded as a result of overuse of the enrichner.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
Mar 26, 2017 | Motorcycles
2001 CBR F4 NOT STARTING NEED HELP??
Hi, Gasper and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
NEED HELP 2002 Honda CBR 600 F4i wont start
HONDA CBR WONT START TRY THESE TIPS
2001 2003 Honda CBR600F4i Service Manual Moto Data Project
OEM parts for Yamaha
Honda CBR600F4i Owner Manual
Nov 30, 2016 | 2001 Honda CBR 600 F(4)i
1997 YZF 1000. Why doesn't it start?
Hi, Joseph and the usual suspects are:
1. Fuel tank empty.
7. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
8. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
10.. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
11. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
12. Faulty neutral, clutch lever, or kickstand safety switch.
13. Faulty fuel pump fuse or relay.
14. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Thunderace Relay Starting Problems Fixed
FZR Won Start The FZR Forum
http://www.r6-forum.com/forums/57-garage-mechanical-help/162715-will-not-start-good-battery-no-clicking-but-no-turn-over.html
http://www.skoglund.nl/Filer/PDF/yzf1000_1996_Manual.pdf
Apr 05, 2016 | Yamaha Motorcycles
2010 Honda VFR 800 Interceptor will not start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
5th Gen Cranks but will not start
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Honda VFR800 2002 2006 Service Repair Manual Download
http://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800 Owner Manual
Jun 27, 2014 | 2010 Honda VFR 800 Interceptor
Ecu fuse keeps blowing
ecu is faulty, short or ground in ecu
Dec 10, 2013 | Cars & Trucks
Honda s-wing 125 won't start
Hi, Chris and the usual suspects are:
1. Fuel tank empty.
New battery but Bike still won start
Scooter Troubleshooting Scooter won start All about Scooters
Honda 125 Scooters SH SES NES PES FES 125 2000 2009 Haynes Motorcycle...
http://www.honda-montesa.es/manuales/FES125_150_07.pdf
Nov 18, 2012 | 2011 Honda SWing 125
1997 GMC Sierra, I keep blowing the ECM 1 fuse, I replaced Fuel Pump relay and Fuel Filter. Does the ECM 1 Fuse Pump the Fuel Pump, also disconnected the Fiter turned on the key and no fuel.
ecm1 is injectors not fuel pump ecm-b is fuel pump its more likely to be a faulty relay for the injectors, it would be a similiar design to this
12900_oil_sending_unit_and_fuel_pump_circuit_80-yoo05im5qhid2i2poe1uh03c-5-0.gif this is for the fuel system, relay for the injector is nearly the same.
Nov 03, 2012 | 1995 GMC Sierra C1500
Now the **** 1993 jeep does not start even after the asd and fuel pump relays click even though i have fuel pressure after the relays click w t f ???
If the check engine light never comes on, on the dash, with the ignition turned on, then the jeep will not start. You should try hooking up a noid light to the fuel injector wires, to see if the ecu is pulsing the injector while cranking. If the ecu does not send a pulse then the crank sensor or the ecu itself is bad and needs repair.
Oct 01, 2011 | 1993 Jeep Grand Cherokee
I need a honda car code , i can't turn on my radio
service manual.
Code Description Possible Cause
0 ECU / ECU signal No signal to ECU
1 Oxygen sensor circuit Oxygen sensor or circuit, ECU
2 Oxygen sensor circuit Oxygen sensor or circuit, ECU
3 MAP sensor circuit Map sensor circuit
4 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
5 MAP sensor circuit MAP sensor or circuit, mechanical
problem
6 ECT sensor circuit ECT sensor or circuit, automatic
transaxle control unit
7 TPS / Angle Sensor TPS sensor or circuit, automatic
8 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
9 CMP sensor CMP sensor or circuit
10 IAT sensor IAT sensor or circuit
11 Idle Mixture Adjuster Sensor Idle mixture adjuster sensor or
circuit
12 EGR system fault No EGR action, faulty EGR valve
13 BARO sensor circuit BARO sensor or circuit
14 Idle Air Control valve circuit / ECU Open or shorted out ignition signal
circuit / No signal to ECU
15 Ignition Output signal Open or shorted ignition output
signal circuit
16 Fuel Injector Circuit Open or shorted fuel injector
circuit
17 VSS circuit VSS sensor or circuit
18 Ignition Timing Adjuster Open or shorted signal circuit
19 A/T Lock-up control solenoid Open or shorted signal circuit,
Lock-up control solenoid lock-up solenoid
20 Electrical Load Detector / Sensor Electrical load detector or circuit
Honda/Acura
Fault Code Definitions (21 - 59)
Chapter 3 22
21 Spool Solenoid Valve Open or shorted signal circuit,
spool solenoid valve
22 Valve Timing Electronic Oil Open or shorted signal circuit,
pressure switch valve timing oil pressure switch
23 Knock sensor circuit Knock sensor or circuit
30 AT / ECU communication signal A AT control unit, ECU
31 AT / ECU communication signal B AT control unit, ECU
35 Traction control / ECU / signal Traction control module, ECU
36 Traction control / ECU / signal Traction control module, ECU
41 Oxygen sensor heater - left side Oxygen sensor / heater or circuit
42 Oxygen sensor heater - right side Oxygen sensor / heater or circuit
43 Fuel Supply system - left side Oxygen sensor or circuit, fuel
system
44 Fuel Supply system - right side Oxygen sensor or circuit, fuel
system
45 Fuel metering - left side Injector control circuit, incorrect
fuel metering
46 Fuel metering - right side Injector control circuit, incorrect
fuel metering
48 Heated oxygen sensor Oxygen sensor or circuit
53 Right Knock Sensor Right knock sensor or circuit
54 CKP sensor 2 CKP sensor 2 or circuit
59 CMP sensor 2 CMP sensor 2 or circuit
Dec 28, 2010 | 1994 Honda Accord
Chevrolet 1985 Chevrolet Blazer S10/jimmy S15 Radio Logo
350 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
