Question about Russell Hobbs Blenders
I need a set of blades, they don't turn .Where can get them.
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to lubricate blade assembly.
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
The blade has become VERY tight and will hardly turn. When I turn on the blender the motor strains to get it turning, and when it does it makes a horrible sound. I've stopped using it because I don't...
put a socket or a wrench on the nut in the middle of the blades, and hold the other set with a set of pliers, and, as the original poster said, it is reverse threaded.
Mar 15, 2011 | Breville BBL550XL 5-Speed Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Blenders Logo
204 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
