Question about Electrolux Dishwashers
My dishwasher did 3 beeps which meant drainage overload so I cleaned tray inside it now I get one beep every 3 seconds I can hear the water filling up but looks like the blades don't go round
Model is ESL6211LO
Posted by Paul lilley on
Dado
    Master:
  • Electrolux Master
  • 511 Answers
Intervention of Anti-flooding system (The cycle is interrupted and the
drain pump switches on)
Could be:
  • Water leakage from the tub - sump and various connections (pump, upper spray arm duct etc.)
  • floating sensor blocked mechanically
  • microswitch faulty
  • fill solenoid blocked mechanically
  • circuitboard faulty (solenoid triac short-circuited)
  • wiring faulty.
Dado
Posted on May 04, 2016
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Whirlpool dishwasher model gu1200 not working
I checked. There is no sheet of any kind inside or below the door of my Whirlpool dishwasher.
In any case, opening up the non-washing washer revealed that the filter behind the chopper assembly was clogged with food. I cleaned it off, put the thing back together again, and it was washing dishes again, until about three days later. I took it apart again and found food clogging the filter behind the chopper. I thought the chopper wasn't chopping, so I replaced it. It was around $16. About three days later it wasn't washing dishes again.
Further examination (dis-assembly of the sump motor and impeller) revealed that the end of the impeller (which is designed to engage the chopper) had broken off, thus the chopper no longer spins with the sump motor. The impeller costs about $20 and isn't too hard to replace, as long and you keep track of what you've dis-assembled and put it back together in reverse order.
On whirlpool dishwashers, the sump motor drives the impeller (it's connected via the threaded end of the motor shaft) and the impeller, in turn, drives the chopper. The chopper you can replace from inside the tub, without removing the dishwasher from its home or taking apart the sump assembly. But save your $16, as that probably isn't what is wrong... The impeller, being screwed onto the motor shaft, requires complete removal of the dishwasher so that you can completely remove the base assembly that holds the motor assembly.
If you have a GU-series whirlpool washer, the tech manual can be found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
It has complete instructions for the replacement of every part.
Posted on Dec 29, 2007
fpreston
  • 7 Answers
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
Anonymous
SOURCE: all 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Posted on Mar 15, 2009
Anonymous
  • 7 Answers
SOURCE: Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Posted on Sep 01, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Posted on Jul 13, 2010
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Lights come on and it beeps when u select cycle but it wont run
Do you hear the water going in? If not, the float switch is probably stuck . From the inside you can see the cover usually on the front left corner on the floor of the dishwasher by the bottom rack. Remove the screw and float cover. The you see a small piece sticking up, gently push on it many time to try to free and clean it. This is actually pushing the float switch. Clean the plastic covers of soap gunk. Reassemble and try. The switch can be accessed from underneath if you want to replace it. Also a clogged or defective water valve will not allow water to enter.
Mar 24, 2014 | GE Dishwashers
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Related Topics: turn beep off beep turn
Hello Craig,
You can use Affersh dishwasher cleaner (link here) http://www.affresh.com/our_products/affresh_dishwasher_disposal_cleaner and to achive "Super hot" wash you can reset your hot water heater to a super high setting and the run a few cycles of the dishwasher....once done be sure to reset the hot water heater to the usual setting...also a very effective cleaner in the dishwasher is white vinegar ,try that along with setting the water heater higher
Good luck,
thanks for using Fixya.com
GENE
Nov 25, 2011 | Bosch SHX4AP05UC Dishwasher
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Dishwasher not getting enough water in either drawer, although top drawer gets more. Dishwasher keeps beeping during cycle and reads not enough water and then stops running until you press the start...
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Mar 07, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Smeg dishwasher Beeps when trying to drain...seems to wash ok but
Check your air gap at the sink for internal obstructions (take it aoart and clean it) Also check the dishwasher drain outlet into the garbage disposal (if you have one) They tend to clog up inside the garbage disposal. You may have to pull the hose off that connects to the garbage disposal to clean the hole out.
Kelly
Feb 28, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
Whirlpool dishwasher ADG 7550. Starts cycle, water fills in then drains and starts beeping. Can be reset by pressing and holding the start button but problem returns on the restart. Any help on this...
high i have the adg7550 and the beeping again and again is the water sensor inside the left hand side.apparentley taking the plug off and cleaning contacts solves the problem this did work for me twice but now its being a pig.hope this helps.
Oct 27, 2008 | Dishwashers
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
