Question about Texas Instruments TI-84 Plus Calculator
I dropped my calculator and now it wont turn on. weird lines are going across the screen when i first dropped, went blurry, then turned off completely. i tried charging and got new batteries.
Posted by Liana Wilkinson on
5 Related Answers
Anonymous
SOURCE: Calculator screen stratified black lines
I've had a similar problem in the past. With mine though it was white lines. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons ever few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Posted on May 12, 2007
Anonymous
  • 35 Answers
SOURCE: weird lines, characters, symbols etc.
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
Posted on Aug 27, 2007
moomoo55
SOURCE: Help!!a Black screen appears when I turn on my calculator
http://oakroadsystems.com/math/ti83oops.htm#Lines
ok guys, after about 10 years of not using my ti-83, i put the new batteries in and got the black screen you are all talking about.. came to this site.. saw no solutions.. kept looking.
I've fixed my calculator, but my brain won't tell me exactly how.. but i followed those instructions..
you CAN see what is on your screen if you tilt it under the light ... just fiddle around until you can see faint writing on your screen under the black.
Press window
i have these entries in my calculator
xmin=-10
xmax=10
xscl=1
ymin=-10
ymax=10
yscl=5
xres=2
then go and press second and the down arrow to lighten your screen. it should work.
Posted on Dec 06, 2007
Anonymous
  • 30 Answers
SOURCE: ti-84 plus
this might seem weird.... but have you checked the brightness of your calculator? if someone was playing with it and set the brightness to 0 it wont seem like there is anything. if u press second then hold the up arrow key it will make the screen darker. I dont know if this will help you or not but i know some of my friends like to play pranks where they set the brightness really high.
Posted on Nov 03, 2008
Anonymous
SOURCE: Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Posted on Sep 18, 2009
Nobis Tablet has blurry screen and is unable to read.
You should go see somebody that's good with electronics.
Dec 26, 2013 | Tablets & eReaders
Screen glitch
Get another calculator.
Dec 17, 2017 | Casio fx-300ES Calculator
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Line across the screen
If it's just a single line then it sounds like that the screen is not connected probably or is shot...
if it's more of a "flurry" or snow... then you can connect to another unit via the I/O cable or usb if your model has it, and use the "send OS" command to start from scratch and lose all data but have a working calculator.
Feb 07, 2008 | Texas Instruments TI-83 Plus Calculator
Weird lines, characters, symbols etc.
Aug 17, 2007 | Texas Instruments TI-83 Plus Calculator
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
186 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
