Question about HP DeskJet Office Equipment & Supplies
How to add to my taskbar - DeskJet HP Office Equipment & Supplies
Posted by Walter Hawse Sr. on
Andy Bale
    Sergeant:
  • 213 Answers
The Printer Icon its self you can't add to the taskbar, but you can add it to the desktop by simply dragging and dropping it there.
Posted on Apr 26, 2016
Putting icons on my taskbar
Very easy to do.
1. click on the window button
2. select all programs
3. right click on the program to pin to the taskbar
4. select more
5. click pin to taskbar
Aug 16, 2016 | HP Computers & Internet
Tip
How to uninstall and reinstall HP Deskjet D2360 Printer
Hi,<br /><br />I think you need to uninstall and reinstall your HP printer drivers.<br /><br />to do this follow these steps:<br /><br /> 1.<br /> Select Start , Settings , and Control Panel .<br /> 2.<br /> Double-click the Add/Remove Programs utility.<br /> 3.<br /> Select the HP Deskjet D2360 Printer and click Add/Remove<br /> 4. Restart your computer<br /><br />To reinstall HP Deskjet D2360 Printer<br /><br /> *<br /> Make sure that the printer is properly set up, turned on, and ready to print.<br /> *<br /> Check that all cables are firmly connected.<br /><br />For Windows XP<br /><br /> NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />For Windows XP Home Version<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /><br />Thanks,<br /><br />LETMEFIXIT
on Feb 02, 2011 | HP Deskjet D2360 InkJet Printer
Tip
Get back the Quick Launch bar Windows 7's new taskbar functions as a program...
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it:
1. Right-click the taskbar and choose Toolbars --> New Toolbar.
2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area.
It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title.
Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar.
You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
on Jan 12, 2010 | Computers & Internet
I would like to display the date also at the right bottom corner of my computer. The time is already displayed there.
Which operating system do you have ?
The Window's taskbar organizes open and running programs, provides a quick way to access application shortcuts, and gives easy to access to important computer functions and utilities via the system tray. Most users of Windows center their workflow around the Window's task bar for its convenience and ease of use. With the clock function automatically enabled, users can add the date to their task bar while increasing the space for more application shortcuts.
Add The Date To The Taskbar In Windows XP/Vista Right-click on your Window's taskbar and click "Lock the taskbar" option to remove the check mark next to it and unlock your taskbar. If there is no check mark next to it, do not click it as your taskbar is already unlocked. Move your cursor to the top edge of the Start menu and wait for it to change into a double arrow. Click and hold the left mouse button and drag your mouse upwards until the taskbar physically changes in . When it does, it will add the day and the date under the time. Add The Date To The Taskbar In Windows 7 Right-click on the Window's taskbar and select "Properties" from the resulting menu. Click the check box next to "Use Small Icons" to disable the option. The icons will get slightly larger and the date will appear under the time. Click "Apply" followed by "Ok" to save your changes and exit the window.
Mar 15, 2013 | Dell Computers & Internet
How to add a taskbar!!!!!!!!!!!!!!!!!
Surely you have a taskbar - otherwise, there is no start menu, or any way to get to anything. Is your taskbar not visible? Possibly it is in "hide" mode - you can move the mouse to the bottom and it will pop up. It may have been moved - you can move it to either side or to the top by simply grabbing it withthe mouse and dragging it where you want it. This means, if your taskbar is hiding, you may have to move the mouse to either side, top, or bottom to find it. If there is no taskbar, you will have to hold the shutoff button in until the computer shuts off, then restart it. Usually this will correct the problem. Try these solutions and see if it helps before we do more drastic things.
Aug 30, 2010 | Computers & Internet
How do you add the volume icon to the taskbar in windows xp?
Click Start > Settings > Control Panel > Sounds & Audio Devices. Check off Place volume icon in the taskbar
May 03, 2010 | Compaq Computers & Internet
Can't find volume control. Not in task bar.
start> control panel> taskbar and start menu> taskbar (first tab)> click on customize on the bottom > find the speaker icon> choose "always show" or "hide when inactive"
Oct 11, 2009 | Dell Latitude D430 Notebook
Before installing Windows XP Upgrade
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP. Uninstall Trend PC-cillin2000 Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000". Click the Add/Remove button to uninstall "Trend PC-cillin 2000". Uninstall NTI CD-Maker 2000* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000". Click the Add/Remove button to uninstall "NTI CD-Maker 2000". Uninstall Intel LANDesk Client Manager* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6". Click the Add/Remove button to uninstall "Intel LANDesk Client Manager". Uninstall PowerDVD* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD". Click the Add/Remove button to uninstall "PowerDVD". * This software is optional. If this software is not installed previously, please skip the step.
Sep 11, 2005 | Acer n10 Pocket PC
37 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
