If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
SOURCE: audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
SOURCE: cb radio mod
to terry 9670....change the loop mixing crystal 11325 crystal.to 11.1125 this will give you nz channel 1-40.might have to retune the vco .any problems email me i have moded lots of cb radios .email.grant [email protected] from christchurch nz.
SOURCE: just installed a connex cx 3300hp not sure of
it should be am selector switch on d/a and hi band
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
