SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
SOURCE: Sony DVP-NS57P all region
Try this,
1) Plug the DVD Power Cord to the wall jack, but DO NOT Turn On the player;
2) With the Remote Control, press: Display, Top Menu, Clear and Power;
3) It will enter in the Service Mode;
4) Choose option 2 and then 4;
5) It will ask for an Input Code and Current Code (its 5 spaces), press 1245 and then Zero;
6) Leave all Zero erasing 1245, and on the bottom field all Zero too, then press Enter;
7) So the DVD Display will show a Zero (all Region-Free),
then press Power to Turn Off.
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be
aware that you will probably void any warranty you have and possibly
even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply
by applying appropriate service codes, you do not need to install a so
called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD
players. There are some encouraging reports out there supporting this,
but nothing has been verified by me. Again, if you choose to apply this
guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at [email protected] and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are
available on the Internet. Unfortunately, not many people have an
appropriate device to enter the codes into. You basically need a
programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ)
with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format
used by Blank Frank's winsamp.exe. Please do not bother Frank with
questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by
using an appropriate command line switch. For example, use COM1 by
running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
