Question about Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Posted by Robin Doescher on
L Pfaff
    Top Expert:
  • Tablets & eR... Master
  • 11,573 Answers
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Posted on Apr 25, 2016
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Mar 31, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My Kindle Fire will not turn on. I charged it all night and it still will not turn on.
USING THE DEVICE EXCESSIVELY WITH THE CHARGER PLUGGED IN WILL DETERIORATE THE BATTERY'S LIFE CYCLE. IF YOU ASK YOURSELF AND KNOW THAT YOU HAVE DONE THIS.... I AM GOING TO BE HONEST WITH YOU,... YOU NEED A NEW BATTERY... ALSO., EXCESSIVE CHARGING WILL WEAR OUT THE CHARGING PORT. HAVE YOU TRIED A NEW CHARGER???
Dec 20, 2014 | Amazon Kindle Fire HD
My sons kurio 4s power button doesn't work. I have to plug it into a charger
Check the battery is charged - it may be duff and need replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops and tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 09, 2014 | Tablets & eReaders
Please help!!!!!!!!!!!!! i don't have the charger for my Itechie tablet so i charge it using my usb cord in my laptop it works fine.. then, i fine a adaptor/charger and i use it.. it's charging so i...
Its cause u used a bunch of different things on it and i dont know anyways to fix it u can go to the company that u got it from and tll them about it they will try and fix it but if it doent fix they might just hive u a new one!!!!your welcome
Feb 17, 2014 | Tablets & eReaders
Tablet wont charge
The DC - In Jack where you connect the AC Adapter to charge is either cracked, broken or loosened in the inside of the tablet. Investigate further on the company's website: enter the make of your tablet, model and serial number. It will show you the part and how much it will cost. It gives you an idea on what to expect to pay.
Parts cost less then the labor.
Jan 17, 2014 | Tablets & eReaders
My LG slate tablet wont turn on
my son charged mine with the car charger for higher voltage charge and its working fine now
Dec 22, 2013 | LG 8.9" 32GB G-Slate Tablet
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Nov 09, 2013 | Tablets & eReaders
Tablets & eReaders Logo
81 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
