Question about Sanyo Televison & Video
I'm trying to hook up an older sanyo TV to my dish network, and I only have the yellow, and white inputs... How do I do this?
  • Sanyo Master
  • 1,692 Answers
Hi Lucas, If your dish network has an aerial in & out then you connect television (aerial in) to dish network (aerial out)......... I hope this helps mate........CHEERS..
Posted on Apr 25, 2016
5 Suggested Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Posted on Apr 12, 2007
Anonymous
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
Anonymous
  • 99 Answers
SOURCE: TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Posted on Mar 21, 2008
Anonymous
  • 379 Answers
SOURCE: cannot hook up ps2 to durabrand model DWT1304
yes , you need to be in GAME mode on the TV , since you don't have the remote you can still access GAME mode from the menu button on the front of the TV . you must be in GAME mode for your PS2 to work. thanks
Posted on Dec 30, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2009
I just need a diagram to show me how to hook the dvd/vcr up to my television. I have Dishnetwork as well. I un-hooked and now I can't get a picture.
Not knowing the model of the TV its hard to tell you how to hook it up. Howeever let's assume that yu TV has an auido in and a composite video input. it it does is should have three RCA jacks on the back...one red, one white and one yellow.
Assuming Dishnetwork is being used as a analog video.
Connect the VCR/DVD player via a patch cable ( usually has three cable all color coded, red, white & yellow) Red and White section is used for the audio Left and Right. The yellow cable is video.
Connect the audio out of the VCR/DVD player to the audio input on the TV. Do the same with the videoout of the VCR/DVD to the TV may be marked "Composite Video". Now connect your Dish Network receiver RF Out to the TV. This should be a coaxal cable.
Now when you want VRC/DVD use your remote and select input. Some older TV's have the aux input just before Ch 2. Some remotes have an input button.
once you have aux inpsut selected turn on the dvd and play your movie to view Dish go to Ch 3 or 4 depending on how your TV and system is set up.
Again not knowing the model TV you have, this is a general hook up.
Thank you Let us know if it helps
Tom Miller
Broadcast Engineer
Sep 09, 2011 | Televison & Video
How do you hook this TV up to a standard Dish network system. We are trying to hook it up and it says no signal.
Hello there! My name is Becki, and I am with DISH Network. I do hope that this has been resolved for you! But if not, here are some steps that you can try. I hope this helps!
You will first want to put your TV on channel 3.
You can use RCA (red/white/yellow) cables to hook up the receiver to the TV.
If you are using a receiver that works 2 rooms, on the back of the receiver, the location for the RCA cables will have a green TV symbol with a 1 on it. That is where you want to connect these cables. Run these then to your TV. Some TVs will give you an input number next to these connections, such as Video 1 or 2.
After these are connected, try to cycle the inputs on your TV. You can do this with the buttons on the side of the TV, or with the remote. Go slow, becuase it can take a few seconds for the input to actually change. If this does not work, try to go to channel 4 and repeat the steps.
You could also use coax cable to connect from your receiver to the TV. The connection on the back of the receiver will simply say channel 3/4. And that is just what you do, put the TV on channel 3 or 4.
If these steps do not work, or you need some clarification, please let me know!
Becki Barned
DISH Network Customer Service
[email protected]
Jul 24, 2011 | Vizio VW26L 26 in. LCD TV
I have a 322 dish receiver there is just too ports to hook to and i have ant.+ cable and sat. to hook to it anyhelp would be welcome. thanks
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Apr 16, 2011 | DISH Network 322 DTV Receiver
I have a zenith tv older model, and have dish network, i need to know how to hook it up and switch it over so i can play it
If you have an HD receiver you will want to use one of two types of cables; you can use component cables which have five ends red, blue, green, red and white, or you can use an HDMI cable which will have one flat connection. If you have a standard definition receiver you will want to use RCA cables these have three ends red yellow white. The connections will be labeled on the television as well as the receiver. Once you get this connected hit the input/source button on your TV set if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
Mar 09, 2011 | Zenith Z50P3 50 in. Plasma TV
I'm trying to hook up my dvd player & recorder but i can not get a picture on the tv. I put it on channel 3,4,60,73 like the book says
Hi donsol45my name is Mike Houston of DISH Network and I was reading over your post abouthooking up your DVD player to play. If you are using RCA cables that have Red,White and Yellow for tips. You can connect them directly to your TV and it willrun off your Video Input 1, 2 or 3 and if you're still having a problem please e-mailme. [email protected]
Feb 20, 2011 | DISH Network Televison & Video
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
I have a older Sony TV. I want to connect my magnavox dvd and older surround sound and my DISH network together. I need a diagram or step-by-step instructions as I am NOT literate to hooking these...
I will ilustrate how you do this .. first your magnavox dvd has a cord,has three defferent color of RCA jack yellow ,red and white,yellow is for video,red is for the rigth speaker and white for the left speaker. the video or yellow cord is input to the TV in the VIDEO 1 section the red and white cord is input to your old surround sound, next is your DISH network the output cord is going to input to the VIDEO 2 section in TV.. the video cord color yellow and the red and white to the is going to input in old surround sound, and the out of your old surround is for the speakers...if happens that your sound is one input by a Y RCA jack ,Y jack HAVE ONE INPUT and two output,,,feel free for asking question for further assistance in the future rate me a fixya.....
Jun 19, 2008 | Audio Players & Recorders
Televison & Video Logo
67 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
