Question about Nook HD+
It will not turn on
It is fully charged. i have held down both buttons alone and at the same time
1st gen kindle won't turn on
OK my Kindle has done that before..stick on charger and leave it there...it may pop on on its on...OK and it could be on just screen is not ..hold power button down for like forty five seconds..then release power button and as quick as u release push it in one good time and release button..that's a reset for Kindle hopefully like like with mine u will see LCD light up ..good luck
Mar 05, 2017 | Tablets & eReaders
How do i restart my tablet /
If the usual methods do not work, try letting the tablet sit while on and unplugged until the charge drains to zero. Then the tablet will shut off. Plug it in and charge it fully and then turn it on. Worked for me and have had no problems since.
May 03, 2015 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Dim light but wont turn on fully
You will need to "reboot"
While pressing down the Nook button (upside down u on the front of the tablet), press the power button on the side. You will need to hold it for couple of seconds.
Mar 07, 2014 | Barnes & Noble Nook HD
Reset klu lt7035 f
get into emergency recovery mode, most Androids use the up/down volume at the same time while turning it on. release the power button when it displays the first logo but keep the volume buttons down till you see the Android logo. volume down button to see the first menu read the screen follow the prompts for factory reset Plus wipe data. ****** warning: make sure your battery is fully charged before doing this *********
Dec 28, 2013 | Tablets & eReaders
Not operating
Check you have charged it for at least 30 minutes.
Press and HOLD the power button in the ON position for a slow count of 30.
Ignore whatever happens and just keep it held on.
Now go drink a cup of tea and let it calm down.
Now touch the power button as normal to turn on.
Dec 21, 2013 | Amazon Kindle Paperwhite
Nook HD+ Logo
Top NOOK Tablets & eReaders Experts
Jean Thiebaux
stynger007
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a NOOK Tablet and eReader Expert? Answer questions, earn points and help others
