Question about Video Cameras
How do i factory reset Sdr-4101n - Video Cameras
1 Related Answer
AndrexT
Andrew Taylor
  • 33119 Answers
SOURCE: I have the SDR-4101N BUT 4321 DONT WORK I CANT CHANGE ADMIN AND I FORGOT MY PASSWORD HOW CAN I TAKE CONTROL OF IT AGAIN PLZ HELP
A similar manual is here, but doesn't mention resetting the unit. Look on the rear for a small hole with a button behind it.
https://www.samsungsv.com/Download/SDS-V4040_User_Manual.pdf
Posted on Dec 06, 2016
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
I need to reset my password on a samsung sdr-5100n
You will need to do a factory reset unless your phone has a PUK code. Contact your cell service provider for more info on the PUK code.
Jun 22, 2017 | Samsung Cell Phones
Changed my admin user and password on samsung dvr sde-4101n And forgot password how do I reset it
there is reset button on the main board in dvr you can press it to get default pass
Mar 14, 2016 | Samsung Home Security
Maintenance code CA
You just need some maintenance, pal.
Have it done and the tech will reset the counter for the maintenance.
If you're in Houston we'd be happy to get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 24, 2014 | Sharp MX-4101N Full-Color Copier/Printer
No picture,had sound,think i changed setting now no sound.
Just do a factory reset to this set, and check. To do it, you've to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 25, 2014 | Hitachi 55HDS69 55 in. Plasma Television
Horizontal line on output
Clean the small long glass aside the big glass.
Jul 03, 2013 | Sharp Mx-4101n mx-4101n
Not able to send scans to my mac
Depends on OS version. Older versions worked vwell via FTP newer OS's include windows sharing (samba) and can be set up SMB. If you don't know what FTP or SMB is you may want to call IT.
Jan 10, 2013 | Sharp Mx-4101n mx-4101n
Video Cameras Logo
498 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
