Do you know how to view a wiring diagram an use a DVOM - digital volt ohmmeter to test electrical circuit's ? Viewing a wiring diagram to see what all is involved in making the blower motor work should be the first step . Video's on youtube showing how to trouble shoot automotive electrical circuits . Then go here for wiring diagrams . http://www.bbbind.com/tsb-wiring-diagrams-database/
Any ideas ???? Yeah , learn how to test electrical circuit's if you want to fix it . viewing wiring diagrams of the non working systems an using a DVOM - digital volt ohm meter to test the electrical circuit's is the only way to find the problem . Voltage drop testing !
On Electrolux dryers, the EH0 (EHO) error indicates a problem with the incoming voltage at the power supply. This can be due to a problem with the electrical outlet, the power supply or the circuit board.
First unplug the dryer or shut off the circuit breaker. Check if the outlet is working by plugging something else into the outlet and checking if it works. Leave the appliance off for 30 minutes or an hour to see if the error resets. If you recently had a power outage, this might clear an issue from an electrical surge. You may want an electrician to check your wiring.
After that, you will have to check if the power supply is working properly or if the circuit board is getting the incorrect voltage information. There should be an wiring diagram and test sheet tucked into the dryer. It's usually in a space accessed from the back of the dryer. Replace the faulty part. If the dryer is under warranty, contact Electrolux and have them service the problem.
I hope this. The parts diagram is available as a PDF here: https://spares.bigwarehouse.com.au/index.php?cPath=64689_77656_94810 .
Doesn't have one . Looking at a wiring diagram to view fuel pump electrical circuit would show that . Do you know what automotive electrical wiring diagrams are ? Do you know how to use one along with a DMM - digital multi-meter to test electrical circuit's ? The fuel pump is controlled by the PCM - engine computer by energizing the fuel pump relay .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model ! Under system click on engine ,then under subsystem click on fuel controls . Click the search button then the blue link. Scroll down to the fifth diagram .Fuel pump electrical circuit . Fuel Pump Electrical Circuits Description and Operation
Well Angela the only way to find out why these thing's are not working or not working correctly would be to do electrical testing ! Find wiring diagrams of the affected circuits an get a DVOM - digital volt ohm meter . Do you know how to do basic automotive electrical testing ? How to use an read a wiring diagram ? Voltage drop testing ? Your battery dying , depending on when it dies , over night or while driving would need different testing procedures . Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Without testing the electrical circuit's we'd only be guessing . Looking at wiring diagrams to see if the instrument cluster & fog lamps share a common ground or power supply would be a good first step. Do you know how to use a DVOM - digital volt ohmmeter to test electrical circuit's ? Do you know how electrical circuits work ? Electric Testing Techniques You Need to Know
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine . Under system click on lighting ,then under subsystem click fog lamps . Check power an ground supply . Then under subsystem click instrument cluster ,check where it's power an ground is . Use voltmeter an test the circuit's . Looking at the wiring diagrams i don't see anything these too have in common , power or ground . All you can do is test the circuit's . Find what's missing .
I have a copy of the service manual which contains service information - electrical adjustments - troubleshooting - spare parts - block diagram - frame schematic diagram. If you want the copy, let me know your email add and I will send it to you for free. Jdvillanueva
