The inverter or backlight on the display may have gone out. Connect an external VGA monitor to the laptop. If it works, then the display has a bad inverter or the backlight CCFL lamp went out.
I recently purchased the same camera (Olympus T-100) and it would do the same thing. Would lock up with a black blank screen periodically. Now, for no reason the screen has turned white and doesn't display anything at all. I went to Olympus' website with hope to download the software for it but there isn't any software for this model. I sent this problem to Olympus for an answer but I think I am just screwed, unless someone has a solution.
To cure the F35 with the occasional SUD fault showing in the display the problem means that you need to unplug the machine from the mains and turn off the water supply. Then remove the lower cover, looking at it from the front where the glass door is, so you can see the water pump. On the water pump there is a round cover, turn it counter clockwise to get it loose, then the the filter will come out. You may find some interesting things in there! Clean it and screw it back on. Make sure the machine is powered off at the mains for 30 minutes in total to reset the computer and clear the fault display. Reconnect the mains power and turn the water supply back on. The machine should now operate correctly.
there is a connection problem with the screen or a graphics chip fault, being as it's only 6 months old, do not void the warranty by trying to remove anything, return to your original selling retailer
YOUR INTERAL DISPLAY ADAPTOR MAY BE GOING BAD, HAVE U TRIED REINSTALLING THE DRIVER , IF SO ITS UR ADAPTOR OR THE SCREEN ITSELF WHICH IS NOT A BIG PROBLEM REPLACING. THE EASIEST THING TO DO IS ASSUME ITS THE MONITOR. DOES IT DO THIS IMMEDIATELY OR DOES IT TAKE A WHILE. WHEN U HOOK UP THE OTHER MONITOR DO BOTH SCREENS WORK.
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
