Question about Denon Televison & Video
How to fix my Denon DBP-4010ud Blu-Ray Player
My Denon DBP-4010ud Blu-Ray Player doesn't play blue ray discs only, it plays every thing ells. What can a do?
Posted by Filipe Goncalves on
Gary F
    Sergeant:
  • 236 Answers
Appears to be a software problem. Unfortunately, some blu-ray players contain software that expires, requiring you to repurchase newer, more expensive software from the manufacturer in order to continue to play blu-ray discs. Check your software for the player. No freeware blu-ray software out there.
Posted on Apr 25, 2016
Nanny
    Genius:
  • Denon Master
  • 2,351 Answers
In players with network interfaces please check via the firmware update function whether you have loaded on the current firmware, and if necessary apply an update. For all players you can find the current firmware at http://firmware.denon-online.eu.
If you still can't solve it and if your laptop is equipped with Blu-ray drive, you can You can s some Blu-ray player program so that you could play Blu-ray discs on your laptop or PC.
Posted on Nov 13, 2019
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
Posted on Feb 15, 2009
Anonymous
SOURCE: Pioneer DBP-51FD Blu-Ray
I bought mine four days ago and it would not pay the new James Bond Blue-Ray. The screen said your player needs an update. I downloaded the firmware, and it still did not work. I took the disc down to Best Buy and it played fine on an identical DBP 51-FD. Their tech came out with a replacement player and it played fine. Now, however, it will not play the DVD Happily Ever After 2, eve after the firmware update. Strangely enough, the other player played that DVD fine.
In other words, take it back and get another one.
Posted on Apr 13, 2009
Stonywall
  • 10 Answers
SOURCE: our blu-ray disc player bdp-s300 won't play newest blu-ray
You will need the following:
1) Internet connection
2) Wired router
3) long enough ethernet cable to reach from your blue ray player to the router.
Step 1:
Eject any disks and turn off the blu-ray player by unplugging it.
Step 2:
Attach the ethernet cable to the router and the other end to the ethernet port on the back of the blu-ray player.
Step 3:
Turn on the blu-ray player and wait for it to load all the way.
Step 4:
Using the remote, arrow over to the left to "Setup", the up to "Network Update".
Step 5:
After the unit updates and restarts, repeat until it tells you "Already Updated".
That should help you play the newer movies, and even some of the older ones.
Posted on Apr 03, 2010
Anonymous
  • 3 Answers
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Posted on Apr 24, 2010
t407803
Juan Torres
  • 84 Answers
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Posted on Apr 11, 2011
Testimonial: "This site was extremely helpful. Received resonse very quickly."
Replacement disc tray needed
That is the (costly) heart and soul of the dvd player! Only chance, go to dvd players throughout Craigslists USA and find a used one.
Here are 8 from Craigslist DFW, going for around $15-25 each. Not Denon but its a start!
Call Andy 972-358-0662
Mar 18, 2014 | Denon DBP-1611UD REGION FREE 3-D BLU RAY...
My denon dbp 2012 makes an awful buzzing/vibrating noise when playing some discs,any ideas how i can fix this?
I have the same player, it was doing the same thing. The reason is because it was faulty, so I sent it back and got it repaired. It played some discs with no problem, but made a noise and in a lot of cases couldn't continue past a specific chapter on the disc.
Nov 29, 2012 | Denon DBP-2012UDCI Universal Blu-ray Disc...
My Denon DVM-1800 says no disc what do I do?
I have had the same thing happen with my blu-ray. I have tried cleaning the disc; the lens, occasionally with success. flashing the bios. also known as update of the system [can be done online {if equipped} of mine also has a usb port {download the correct file to a USB drive and re-power DVD with the drive in place}]. if these things don't work try manufacturer tech support. I had mine replaced because it wpould NOT flash. good luck.
Apr 07, 2012 | Denon DVM-1800 DVD Player
How to unlock the region coding for Denon DBP-1611?
Hi Guys, i like to make my DBP-1611 Denon Blu ray regio free, can anyone help-me PLEASEE??
Thanks
André Curti
Dec 06, 2010 | Denon DBP2010 BluRay Player
My sony DBP 300 is not playng the Disc . It plays the beginng of the disc but seems to freeze and we are unable to play the blu ray disc movie
Try selecting another disc to play, if the next disc plays, it may be the first disc that will not play, also make sure that it is not a 'burnt' copy, if it is....the copyrights may have prevented it from the format being proper. if second movie does not play, it may be the reader inside is dusty/damaged. Also look at dvd disc to make sure it is not smudged/scratched or dirty. take appropriate cleaning measure if it is smudged or dirty,
Oct 17, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Stopped playing Blu Ray discs, but still plays DVDs...
Have you tried upgrading your player's firmware? I have the same model, and had similar problems playing newer Blue Ray Discs.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 12, 2009 | Sony BDP-S350 Blu-Ray Player
Apr 10, 2009 | Pioneer BDP-51FD Blu-Ray Player
Televison & Video Logo
222 people viewed this question
Top Denon Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
