Printer only prints total black sheets of paper
SOURCE: Paper completely wrinkled
I have two HP LaserJet 1300n printers and like all printers after use (or misuse) they will need PM or repair. The problem with the paper wrinkling is easy. If you have worked on printers then you can make the repair for about $8 - $20 and a couple hours. You can find the service manual at HP's website or online. It is typically a roller or the fuser film is torn. Disassemble the printer/fuser in accordance with the service manual or break out pic, clean, replace part and reassemble. For those who do not want to DIY then you can buy the entire fuser assembly on multiple sites anywhere for refurb w/core exchange to new for $70 - $150. The printers are good printers but like all mechanical devices, they will fail...it's just when and how.
SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
SOURCE: Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
SOURCE: Problem printing multiple pages on one sheet!
The problem is the PCL5 driver.
Replace it with a PCL6 driver.
Apparently, Microsoft issued an update that broke PCL5 drivers.
Perhaps they were trying to save paper. LOL!
SOURCE: After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Testimonial: "Solution worked great and will save future trees by not wasting paper! Thanks for the help."
