Computers & Internet Logo
C
Carol Wash Posted on Apr 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shut computer down properly - Computers & Internet
Gary Tiedeman
Level 3:
Master:
  • Master 333 Answers
  • Posted on Apr 28, 2016
Gary Tiedeman
Master
Level 3:
Master:
Answers
333
Questions
Helped
89295
Points
1462
Hello my asus dont completely shut either i have to hold down the power button for 10 seconds. i did browes the net for fair while and none of the answers worked for me , i think my problem started after a windows update ????.( wifi stays on)
tip
Quick Tip: How to correctly shut your computer down
This may seem like a simple tip, it is, however it can cause many unneeded problems to your computer if you do not shut it down properly. Do Not shut down your computer by pressing the power button. Whether you have a PC or a laptop, don't use the button. When you go to shut your computer down go to start and shut down and it will shut off. If you do not do this correctly it doesn;t give your computer the proper amount of time to shut down, you can corrupt your Windows files and eventually have problems even booting your computer up. Simple solution that will avoid future problems! Hope this helps!
Lori
on Oct 18, 2010 • Computers & Internet
Hp P6653 won't shut down properly after clicking shutdown
Open Control Panel, select Power Options, select High Performance, Use this procedure to set the Advanced power settings: http://www.makeuseof.com/tag/windows-7-power-options-sleep-modes-explained/ Use these tip to speedup starts and shut downs: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Try Freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot.
2answers
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
1helpful
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Gets very hot and shuts down
The cooling fan is not working properly. Any computer is designed to shut down if not cooled at the proper temprature. The fan can be purchased through most websites such as tigerdirect.com
1helpful
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Is simply shutting the notebook a safe way to
The proper way to shut down a computer is to click on START - Turn off Computer - then click Turn Off.
CORRECT WAY TO SHUT DOWN. MY OLD COMPUTER A GATEWAY IT WAS NECESSARY TO GO TO SHUT DOWN IN ORDER TO DO THIS. I FIND NO SHUT DOWN ON THIS HP
i am assuming this is Vista, becassue for some reason the shutdown button does not show up by default.
check on the link below on how to get them out so that you will be able to shut the machine down properly.
http://www.arsgeek.com/2007/05/18/how-to-make-your-vista-shutdown-button-actually-shut-down-your-computer/
if you have other questions please lemme know.
11helpful
4answers
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Grand Canyon Tech
Grand Canyon Tech
