Yes, you can use your CDC634 with your ARX6270R. The CDC634 has a round C-Bus connector and the ARX6270R also uses a round C-Bus connector so the two devices will connect together.
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
i have just got the same cd changer from a mate, it had a FMC200 controler, i think the fmc200 module plugs into a head units ariel slot and the cd changer, transmits a radio frequency which your head unit picks up.... not to sure as i have just got the unit with all the paper work and manuals
It would be fairly hard to do that - even if you matched the wires perfectly there's no guarantee that the data protocol for controls would be similar.
Here's a link to a UK vendor of replacement cartridges - if you're not in mainland UK e-mail me (crenner_tech support at hotmail dot com) for a vendor in your location.
