Question about Brother LS-1217 Mechanical Sewing Machine
Upper tension dial is working
I got the dial off and got it to turn now I can't get it back in. Can I still still do this or do I need to replace it?
Posted by Cindy Mace on
  • Cindy Mace
    Cindy Mace Apr 22, 2016
    Also, know anywhere I an get a repair manual, have owners, it just tells me how to use the machine.
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Upper tension won't adjust
You can try "flossing" the tension with a piece of unwaxed dental floss, a dollar bill, or a piece of fabric to try to clean anything that is trapped between the tension discs loose. Be sure the pressure foot it up and the tension knob turned to "0" before trying this. Then dial back the tension to your normal setting and try re-threading your machine. If this doesn't work and you know how to remove and reinstall your tension assembly, that could be the next step. The tension discs do wear out over time, but sometimes it is just some lint that needs to be cleaned out.
Chris
Mar 26, 2014 | Kenmore Sewing Machines
Upper tension dial on White sewing machine turns complete circles
try a top tension of 4 or if you have a automatic setting try that
if that doesn't help then the tension dial need to be checked
to see if some thing is wrong with it, it might need to be replaced
Sep 09, 2012 | White Sewing Sewing Machines
Sewing machine tension problem
if you've tried to adjust the top tension & the dial is not responding then the tension dial may need to be replaced because sometimes they do go bad
a sewing machine shop can tell you for sure
Mar 10, 2012 | Sewing Machines
When I start sewing the back of thread is all overlap and tangled what can I do?
A more detailed description would be helpful, but my guess is that you have lost all of your upper tension.
Unthread the machine. Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Kenmore 19233 Computerized Sewing Machine
Hi, I'm trying to sew a silky fabric and the stitches on the bottom keep getting jumbled and the top thread breaks
My guess is that you have lost all of your upper tension and you may have your needle in backward.
Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Remove the needle and replace it making sure that the flat side of the needle shank is to the back. Thread the machine.
Test sew.
Oct 29, 2010 | Husqvarna Huskystar 215 Sewing Machine
Thread tension dial on riccar sewing mach. needs repaired
Please, tell me, is the main spintle, still on the machine, or it came off with the rest of the parts?
If you can put the tension parts, the one next to the other in front of the machine, and upload a photo for me, it will be very easy to explain how to put them back.
May 24, 2008 | Sewing Machines
Tension issues
I'm working on 2 different singers. One, Singer 3343C has upper and lower tension problems that turning the dial just doesn't help. How do I adjust the tension on this drop-in bobbin carrier? My other machine is Singer Model 15 (AL311850), I'm having upper tension problems and the machine is sewing loudly-it's never done that before. Help!
Oct 01, 2007 | Singer 3343 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Paul Bade
tina gallow
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
