Question about Razor Toys
Razor Rebellion motor not working when I turn the throttle brake is disconnected tried that
Posted by Cary Davis on
2 Related Answers
jimmy5225
jimmy jinx
  • 456 Answers
SOURCE: I have a razor 24volt electric scooter it's charged but I turn the throttle the motor don't turn but will if I jump a wire from battery to motor
it could be the control box. check under the scooter. the photo shows everything needed to make it run. throttle to control box/box to motor/
Posted on May 31, 2015
mechanicbenn
Benn Carkhuff
  • 210 Answers
SOURCE: Razor mini Cooper motor not working when turn throttle tried disconnect brake no good
The throttle goes bad on those razors. You need to wire in a pushbutton toggle switch that can accept 24v... it is cheaper than buying the throttle but, it will be full on but, it is not like the thing is that fast.
Posted on Apr 21, 2016
Apr 21, 2016 | Mini Cars & Trucks
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
Aug 13, 2014 | Sport & Outdoor - Others
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
It makes clicking noise when you use the throttle
Thats the controller relay clicking....if it won't move disconnect the brake switch connectors from the controller and try again. Make sure the batteries are fully charged and in good condition. There should be at least 12.6v or more on each of them with no load. The green light on the throttle should be on when you turn the switch on. If it goes to yellow and/or red when you give it throttle, your batteries are probably weak. Then connect the battery wires directly to the motor and see if it works. If the motor operates and it wont go you need a freewheel. If none of this helps try shorting the power switch wires with your screwdriver or a piece of wire. Sometimes the contacts have too much resistance.
Feb 03, 2013 | Razor MX500 Dirt Rocket
The scooter will go but when throttle is released it keeps going and won't slow down?
I had this problem too. U need to twist on it and jam it until it turns off. Twist it back/forward. U can also pull in brake. The brake automaticaly deactivates motor. Hold brake until STOPPED then let go. The scooter will stay
Jun 18, 2012 | Razor E100 Electric Scooter
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
Jul 18, 2011 | Razor MX350 DIRT ROCKET - BLUE
Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
Razor 350- Does not run
We were having the exact same problem bought this machine a year ago it ran one time and not again. it would click but nothing else would happen the battery tested god we disconnected the brakes and it works! hope this helps you!!!! yayyyyy
Mar 08, 2009 | Razor MX350 DIRT ROCKET - BLUE
Toys Logo
57 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Toy Expert? Answer questions, earn points and help others
