Cars & Trucks Logo
Cary Davis Posted on Apr 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Razor mini Cooper motor not working when turn throttle tried disconnect brake no good
Benn Carkhuff
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Apr 21, 2016
Benn Carkhuff
Expert
Level 2:
Sergeant:
Answers
210
Questions
0
Helped
53116
Points
751
The throttle goes bad on those razors. You need to wire in a pushbutton toggle switch that can accept 24v... it is cheaper than buying the throttle but, it will be full on but, it is not like the thing is that fast.
Im looking for the rear brake light fuse in a 2005 mini cooper
Are all 3 brake lights out or just one. There seems to be several issues related to the brake lights. Also what model Mini?
1helpful
2006 mini cooper s
Susan, Unfortunately, when the battery died, the vehicle may lose learned idle position, which will cause the vehicle to stall and could run erratic. Check the attached links,instruction and guides to see how relearn procedure may be done. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why Is My Engine Stalling After Replacing the Battery
http://www.mini2.com/forum/first-generation-faults-fixes/71424-cooper-s-rough-idle-possible-fix.html
ECU Reset How MINI Cooper Forum
Battery Replacement and Battery Tender Installation
2006 mini cooper heater is not working
mini cooper s heat not working - North American Motoring
www.northamericanmotoring.com/...2006/243158-mini-cooper-s-heat-n...
Jan 2, 2013 - mini cooper s heat not working R50/R53 :: Hatch Talk (2002-2006) ...Any way to determine if the heater core is clogged? And could it be ... Overheating issue / heater not working
Jan 18, 2012
No Heat!!!
Nov 5, 2011
2008 MC Heater Problem
Nov 2, 2008
Heater stops working at idle, Engine overheating light comes on at ...
Apr 10, 2008
More results from www.northamericanmotoring.com
MINI COOPER 07 heater blowing cold air-HELP - MINI Cooper Forum
www.mini2.com > ... > Second Generation Faults & Fixes
Mar 6, 2010 - I too have a 2007 Mini Cooper with heater problems. It now has 96,000 miles and I have just started having this problem. Heater will not blow out hot air bottom or top vents when ideling or low speeds .... Join Date: Nov 2006. Heating not working - mini one 02plate - MINI Cooper Forum
May 15, 2012
2002 Cooper S lukewarm heater - MINI Cooper Forum - Mini2.com
Oct 25, 2011
Problem with heater blower - and no resistor pack to be found ...
Mar 21, 2011
mini cooper 02 HEATER NOT WORKING? - MINI Cooper Forum
Jan 19, 2010
More results from www.mini2.com
Heat not working, MINI overheating! - Motoring Alliance :: MINI ...
www.motoringalliance.com > ... > 1st Generation MINI > Cooper S
Convertible roof not working properly
Why would the battery be disconnected for front brake pads? Did a garage do this? Srange!!!
Roof sensors and switches out of sync after battery removal. Needs competent technician and GT1 computer to sort out.
I have no brake lights on my mini bulbs are good
Usually a problem with the turn signal switch.
2helpful
Trick to Mini Cooper 2003 rear brake calipers?
Mini cooper rear calipers pistons must be rotated as they are compressed. As you look at the face of the piston, it is rotated clockwise.
1helpful
2answers
Rear brakes mini cooper
You rent (or buy) a piston retractor tool. It screws the piston back in place. I found mine for around $50. Saves a lot of time and aggrevation to use the tool.
2002 Mini Cooper Brake Disc Wear
it may be time for new brake pads, and you usually want to replace your rotors when you change pads, you can get away with not doing and instead take it to a shop and get them "turned"
if you want to see for yourself if it's time for new brake pads just remove one of your wheels and look at your brake pads (they are the what actually make contact with your rotor) and if the pad itself is less than the width of about 2 or three credit cards, then it's time for new pads.
hope that was helpful....good luck!
2answers
How do I reset my brake pad service light 2006 mini cooper
If I was working on it I would disconnect battery to "try" to reset the computer usually i have managed to succeed doing so wait a couple of means with both terminals off before reconnecting them.
Top Mini Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sam Akber
Sam Akber
Are you a Mini Expert? Answer questions, earn points and help others
