Install a brand new needle. Make sure you are using thread and needle that are compatible with the fabric you are sewing.
Change the type of thread you are using. Old or bargain bin threads will frequently cause problems.
Clean the tension disks to make sure there is nothing stuck that is preventing the thread from feeding.
Remove all the thread and re-thread from the beginning. FIRST raise the presser foot so the tension disks will allow the thread to seat properly. (Consult your owner's manual.) Make sure you are threading everything in the proper sequence and not missing any steps.
Set the upper tension at the halfway point between the high and low number.
Stitch a test on a piece of your scrap fabric from your project.
The ideal tension is when the upper thread and bobbin thread meet in the middle of the fabric. If the bobbin thread is appearing at the top of the fabric, your upper tension is too tight and needs to be loosened. If the upper thread is appearing under the fabric or forming a loopy mess, the upper thread is too loose.
Keep adjusting and testing until the tension appears correct.
If the thread continues to break, then there may be a burr that is catching the thread and breaking it. Or the timing could be off. Take it for service.
http://www.schmetzneedles.com/all-about-needles/
http://www.sewingandcraftcorner.com/why-does-my-thread-keep-breaking-while-i-sew/
