Question about Samsung RS2630SH Side by Side Refrigerator
Mother board fried - Samsung RS2630SH Side by Side Refrigerator
Posted by Manish R on
Ms 1745 mother board won't power up
This isn't much of a solution, but I can tell you one thing. If the mother board smells like ozone, it's fried. Sometimes you can see where by comparing the clarity of the circuit routes. Sorry if this isn't much help,but if the board is no good then searching for a fix is pointless. GOOD LUCK. Hope it's something less severe.
Jul 02, 2012 | MSI K8MM-V Motherboard
Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
I used the wrong adapter by mistake now my laptop wont come on, i'm sure i fried something , the only thing it does, is the power lightly faintly clicks very rapid. Nothing else.
Yes you are correct. Due to wrong adaptor the power supply known as SMPS gets fried and causes mother-board damage too. So you need to repair your laptop's mother-board components and power supply too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 30, 2009 | Computers & Internet
After lightning struck in my backyard, printer won't turn on.
HI, this was an unfortunate surge that has fried the power board Assembly in this unit. it has also fried the main control. this may be a total loss unless, you are considering replacing the entire mother board and power assembly as well.
Replacing the main control board and power board will restore proper function.
May 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
HP Pavilion a1000 won't power up
usually the brown outs fries the mother board when the power supply fries on these computers
Dec 22, 2008 | Nikon N75 35mm SLR Camera
Dell optiplex g1
Sounds like your mother board is fried, when you change out a battery sometimes static electricity builds up on your finger tips and zap and in most cases you wont notice it, it only takes a little bit to fry a mother board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 15, 2007 | Computers & Internet
Samsung RS2630SH Side by Side Refrigerator Logo
181 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
