Panasonic DV mini camcorder error message
Inside is a sensor that detects moisture. If there is dew inside the unit, the tape will adhere to the head and create all kinds of problems. This sensor is there to to prevent problems. That being said, the repair for this could be as simple as ejecting the tape leaving the unit open and letting it dry out. It could also be a bad sensor. In the case of the sensor, the parts cost would be in the $10-$20 range. Add in the local labor rate ($175 here in Mass) and you have the total repair cost. While this is not the easiest repair because of its size, anyone that works on camcorders will find it straightforward.
Dan
