Question about Samsung SCX-4216F All-In-One Laser Printer
Interrupt soon as start print procedure. Reset and start again. All lights go down and looks like turn the power on.
Posted by Robi DR on
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
Check Smps ?
Posted on Jun 25, 2016
Reset drum
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Sep 06, 2010 | Sharp AL-1651CS All-In-One Laser Printer
Epson stylus 4800 pro. It was printing dye sub 3 out of 4 colors. I cleaned the capping station and put simple green under the heads to soak them, now it prints nothing not even on test print it says the...
most of the time after performing maintenance after receiving an error msg the error messages have to be reset to tell the printer that it can print again
this is 4 procedures depending on your problem one of them should fix it
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it’s home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it’s processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Procedure 4 - Cheat with Software Reset Methods! There is a software reset method that can be used to reset ink levels. It is recommended to use in Epson service centers. Each printer model has specifyed service (adjustment) program which has such option like Reset Protection Counter when you need to reset the value of Wate Ink Counter. You can learn more about software reset method at this link: About Service Programs.
This programs can be used to reset a number of counters in the printer, etc. Please note that CIS users should probably steer clear of any resetting of cartridge ink levels in the printer, and you will probably need to look for the ‘Protection Counter’. Due to the risks of resetting this protection counter, it may be preferable to use the software once to reset the counter, then uninstall it so you do not inadvertently reset the counter more than once.
According to it’s own readouts, it did reset the ‘protection’ counter... but pretty much did so of it’s own accord. It then seemed to interfere with printing! However, the access to advanced cleaning function control etc looks useful. Nevertheless - use with caution as per the notes above!
hope this helps
Robb
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
I have conon mx 868 but i have got error message 6502 and 150 how can i solve the problem?
Here are instructions:
The MPTool is designed for service works with the printer Canon MP-Series
when in Low-Level mode. This is NOT the same as "service mode"
Currently supported for
MP150, MP160, MP170, MP180, MP450, MP460. MP150, MP160, MP170, MP180, MP450, MP460.
BEFORE activating MPTool...you need to
To activate LOW LEVEL mode:
1. Unplug the power cord to the printer for a moment.
2. Then, hold down the on/off button while plugging in the power cord. Keep holding the on/off button down.
3. Right away the green power light (in the button) will turn on solid. Keep holding the on/off button down.
4. Press and release the Stop/Reset button.
(the button w a red triangle in a red circle)
5. Now you can release the on/off putton.
The green power light will go off and the yellow Alarm light will stay on.
Now you can run MPTOOL and resetting the ink counters will work.
Your printer will show up as "another" Cannon printer.
When you finish you must again unplug the power cord for a moment and then just plug it back in. After you do this, you'll see both printers listed in Printers (controll panel) and one will show as offline. You can then rename this offline printer as "Low Mode Canon"
or whatever works for you so you don't mix it up with other functions.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
For
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Reset manual "Ink Absorber Full"
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again
Canon MPC INKTank FULL
button pressing
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Apr 08, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Power light flashing and red light on button 2 will not print
Hi
Thanks for using FixYa. There are two step-by-step procedures to resolve the issue—
Procedure 1
  1. Turn off the printer and ensure that the print head is at its home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable for at least 20 seconds;
  3. While you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds then release the button;
  7. The printer will now attempt to reset, including resetting the EPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  1. Turn off the printer and ensure that the print head is at it’s home location and locked in place as normal;
  6. Allow printer to complete its processing then turn it off for a few seconds and turn it again on.
By following the above any one of the step-by-step procedure, the printer will start printing normally.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 03, 2009 | Epson Stylus 680 InkJet Color Printer
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
Developer light and technician indicator were on
Hello sir; That's PM light, you may go to simulation 20, 21,and 26 to reset; Press"#" "interrupt" "c" "interrupt' then enter 20 press print enter 01 press print, to clear PM counter, now same procedure go to simulation21 and 26, on sim.21 sub code 1 set no PM at 1, on sim 26 sub code 36 set on 1. after all done press clear to exit.
Jul 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
E studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Apr 13, 2009 | Toshiba Estudio 200L Copier
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Sep 14, 2007 | Office Equipment & Supplies
Samsung SCX-4216F All-In-One Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
