Question about LG Microwave Ovens
How do I reset my LG privilege microwave
How do I check to see if it is in demo mode
Posted by Bonnie Downs on
5 Related Answers
Anonymous
SOURCE: DEMO MODE
Had the same problem- we unplugged it and plugged it back in. All is well!
Posted on Jun 02, 2008
tronic21
  • 5 Answers
SOURCE: Stuck in Demo Mode
I will need a model and serial no to further assist you
Posted on Jun 19, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Stuck in Demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't work, check the owner's manual.
You should be able to download your Panasonic owner's manual here.
Posted on Dec 07, 2008
Anonymous
  • 41 Answers
SOURCE: microwave stuck in demo mode
press 'function' '0' '2'
Posted on Sep 14, 2009
Anonymous
SOURCE: we had a power blackout now my panasonic genius
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Posted on Oct 08, 2009
How do I get out of demo mode on a NN-A524M panasonic slimline microwave?
You can clear it if doesnt take it to the technician its must be reseted
Sep 16, 2014 | Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
How do I get my microwave out of the demo mode?
You can reset it by unplugging the oven for about 1-2 minutes, plugging it back in, then setting the clock.
Otherwise, refer to the owner's manual.
If for some reason, you don't have yours, look for it here.
Jan 30, 2013 | Samsung MS1040BB Microwave Oven
My microwave has gone to "DEMO" mode. Why & how do I correct it
mcdevito75 here The control circuit board may be bad, check with any appliance repair outlet in your area.
Jun 28, 2010 | Panasonic NN-H275SF Microwave Oven
We had a power blackout now my panasonic genius microwave is stuck on demo mode. How do I get it off demo mode?Is it fried or fixable?
DEMO MODE ON/OFF
Mar 07, 2009 | Microwave Ovens
It says demo mode and there is no heat, everything else works
Have you checked your manual to see how to get out of demo mode? Since it is still in demo mode, you won't be able to use it for anything else. If you don't have the manual, go to GE's website and download the manual there. Also, you can check their site for Support and look for troubleshooting.
Feb 03, 2009 | GE XL1800 1100 Watts Microwave Oven
Stuck in Demo mode
Dec 06, 2008 | Microwave Ovens
GE Microwave DEMO MODE
The owner's manual (which can be downloaded here) doesn't show any demo mode, but it may exist.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Oct 06, 2008 | GE JE1590 Convection / Microwave Oven
Turn off Demo Mode on goldstar Microwave
Otherwise, try holding CLEAR for 3 seconds, then try each pad for 3 seconds.
Sep 07, 2008 | Goldstar MV-1615 Microwave Oven
How do I take it off demo
timer button 4 time on demo mode
time button 4 taps more off demo mode
see page 11 of your manual
please rate me for this
Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
Microwave Ovens Logo
357 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
